Go to Post FIRST MANTRA: When Lawyer-ism fails, Gracious Professionalism Prevails! - sanddrag [more]
Unread 12-01-2015, 01:55 PM
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Electrical 'Clutch' for winch
I am doing a project where I will be making a winch that needs to release and unspool freely. I am using a banebot gearbox (64:1 most likely) and a bigger motor I found (~400 watts) and I want to winch a 300lb load around a 1" shaft. I was looking at a bunch of 'Shift-to-neutral' mechanisms from 2014 but I decided that they are rather big and might not fit in my project. I was also looking at electromechanical clutches that have 120in-lbs of torque holding capability, but I assume that it won't be enough with the largest gear ratio (4:1) (the strap I am winching is around 3/16" thick, and I am winding about 1ft so by the time I winch all of it, it could be more than the torque rating)
Does anyone have any other suggestions?
//TODO: make signature
Unread 12-01-2015, 03:09 PM
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Re: Electrical 'Clutch' for winch
I think a few more details are needed for a good answer.
You mention a size restriction - what is the restriction?
What resources do you have? Just 12V power? Pneumatics?
Does it have to wind on a 1 inch shaft?
A sketch would work wonders here. A description of the task would too (especially so that you take safety into consideration since it seems you are working with a large load)
Another caution about using Banebots gearbox is that they have a torque limit after which all the gears inside shear off their teeth. I haven't looked in a few years, but it used to be 85 ft-lb.
One solution may be to adapt your motor/gearbox to drive something like this:
http://www.harborfreight.com/1200-lb...nch-65115.html.
To release you can drive the motor to release the load from the winch spool and use a second <something> to pull the stop out and unreel (you can use a smaller <something> if there isn't a lot of weight on the winch spool)
-matto-
Unread 12-01-2015, 03:19 PM
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
This probably isn't quite what you were looking for. But this is what my team did in 2014 when faced with a simular challenge:
http://www.chiefdelphi.com/media/photos/39470
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 12-01-2015, 04:49 PM
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
If you're looking for a ratchet-release mechanism, check out McMaster-Carr gear pawls.
Not sure if this is what you're looking for, or if it's within your budget ($45), but it's a quick way to non-backdrivable mechanisms with a release (lifting the pawl out of place). Also, the gears are stainless steel but I couldn't tell you the stress rating without putting it into CAD.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 12-01-2015, 05:08 PM
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
If you are willing to spend a few bucks, I would recommend looking at one of these:
http://www.harborfreight.com/2500-lb...rol-61840.html
Unread 12-01-2015, 06:55 PM
Slave to the bot
AKA: Chad Krause
Team Role: Driver
-matto-
It doesn't have to be 1", that is just my initial thought. I was either considering the banebot or the versaplanetary gearbox. 85 ft-lbs is over 1000 in-lbs am I wrong? That should be enough for around 300 lbs. I was also thinking of spooling it up, locking it in with something, then despooling it, then releasing the lock, but I am worried about having it snag or something. I was thinking about a winch, but they are too wide. It needs to fit within a 10x6x4 inch box.
I have about 32v to work with, but I was thinking an sensored Brushless RC motor with 8.4v (2s Lipo) that can pull around ~400w at a high enough ratio would be perfect. I like that route because the banebot is a 550 size and this motor I have in mind is a 540 size, same output shaft diameter. It wouldn't be too hard to fit the motor to the gearbox. This isn't for any FIRST robotics project so I can use pretty much any resource.
Thanks for the reply!
Unread 12-01-2015, 06:56 PM
Slave to the bot
AKA: Chad Krause
Team Role: Driver
I like this design a lot actually, it fits my size requirements perfectly (from what I can tell.) Is there a way this thing free spools? If so, that would be almost perfect for me.
Unread 12-01-2015, 07:56 PM
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
It think they are using a VEX Shirter Output Shaft. One position the winch engages the pawl the other position it free spins.
Unread 12-01-2015, 11:09 PM
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Thank you. It has a pneumatic cylinder that disengages the spool from the rest of the mechanism so it can free spin.
Ours was machined custom, and it did take some fine tuning to get right. I do think however, that a similar setup could be createdusing the vex shaft.
Unread 12-02-2015, 12:08 AM
Slave to the bot
AKA: Chad Krause
Team Role: Driver
Do you have any designs or pictures of that? I don't know how exactly I would go about using a pneumatic cylinder to disengage the spool.
Unread 12-02-2015, 12:20 AM
Knufire Knufire is offline
5188 has a ball shifter engage/disengage the motor + ratchet from a winch in 2014. We had a VP with a 18T gear and a ratcheting wrench on the output shaft. The 18T gear drove a 50T ball gear; when the ball gear was disengaged the winch was free to spin. When engaged, it could drive, but only in one direction.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 12-02-2015, 12:34 AM
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I would think it works the same as a standard ball shifter, only when you pull the piston out and the balls drop back in it goes into "neutral", so it unwinds.
Unread 12-02-2015, 02:27 AM
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Here's some more links that might help explain it:
http://www.chiefdelphi.com/media/photos/39469
http://www.chiefdelphi.com/media/photos/39455
The pneumatic cylinder connected to blue piece in the pictured cross section view.
