Go to Post Dash Board: Hey Robot, here is some new data. Dash Board: Robot, did you get that data yet? Hello? Robot: Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks!... Other Robots: Will you please shut up? - EricVanWyk [more]
Unread 01-12-2015, 16:42
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: WCD off season chassis from 2471
Unread 01-12-2015, 16:46
Harman341 Harman341 is offline
FRC #0341 (Miss Daisy)
Harman341 is a glorious beacon of lightHarman341 is a glorious beacon of lightHarman341 is a glorious beacon of lightHarman341 is a glorious beacon of lightHarman341 is a glorious beacon of lightHarman341 is a glorious beacon of light
Re: pic: WCD off season chassis from 2471
I don't see any chain. Is that chain-in-tube or are you just powering the middle wheels?
Unread 01-12-2015, 16:47
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Are you going chain-in-tube to power the corner wheels?
Are the two vertical 2" x 1" tubing pieces on the left side (as pictured) corner wheels encoder mounts? Why do they stick up above the height of the frame?
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 01-12-2015, 17:12
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Is see the question I was going to post has already been asked...
OP please to tell.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
Unread 01-12-2015, 17:25
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
It's a chain in tube design
They are encoder mounts. They stick up to accommodate the gears that run the encoders. I'm not sure why they were done that way, as I was not involved in their design.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 01-12-2015, 17:50
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
What lead you to choose to use tensioners with your design?
One of the major benefits of the in-tube design is that it's practically impossible for a chain to jump the sprocket, especially if the center-to-center distance between the sprockets is correct.
Unread 01-12-2015, 18:24
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I was not involved in that decision, so I can't say for sure. However, I do know that bearing blocks were used so that the the frame could use .0625in wall tubing.
Unread 01-12-2015, 18:46
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Do I spy shock absorbers? Or is that black ABS for spacing?
GitHub
Unread 01-12-2015, 21:44
RobotsThatWork's Avatar
RobotsThatWork RobotsThatWork is offline
AKA: Adithya Bellathur
FRC #0649 (M-SET Fish)
RobotsThatWork is an unknown quantity at this point
for your chain in tube design, are you using 2"x1" tubing? if so, are you using COTS sprockets? I haven't been able to fit 2 COTS sprockets into the tube. It would be great if anyone could tell me how everything was packaged together.
Unread 01-12-2015, 22:00
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
I can't speak for team 2471, but these fit. A version broached for 1/2" hex is available in the drop down selection box.
Unread 01-12-2015, 22:12
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I'm not sure how cots sprocket don't fit? Do they not fit due to the diameter or the width of the sprocket or both?
R.C.
MadTown Robotics Team 1323
Unread 01-12-2015, 22:15
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Yes, and yes. They are plastic spacers. We designed the bumper mounts that way to help insulate the frame from impact. This year's BunnyBots competition has no rule against high speed ramming, and looks to be highly violent.
It was designed to use standard vex spockets, but because they were out of stock, we ended up using steel sprockets with shortened hubs. I don't know the exact layout.
Very nice, I was unaware that they were availible in hex.
Unread 01-12-2015, 23:06
Two 16 tooth vexpro sprockets do not sit next to each other inside the 2x1x1/8 (so width). This is true for both when bearings are press-fitted, and when I use a versa bearing block. The Sprocket with Chain attached to it has a total diameter of 0.491 inches. When I put 2 back to back it would be too wide to fit inside the boxtubing. Any solutions?
I haven't looked into the 17 tooth double sprocket, but can you create a dropcenter with the larger diameter? I know the clearance is pretty slim already for 16t, but I don't know for sure with 17t.
Unread 02-12-2015, 07:59
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Very nice and clean drive base. I want our team to look into a chain-in-tube design this year but I've always wondered how you assemble the chain and sprockets in the tube Care to give me some insight on the procedure? Are there access hole on the underside? Has anyone ever done this with belts?
Unread 02-12-2015, 08:09
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
What we've done is loop the chains around the sprockets and then drop the entire thing down into the tube. Then slide the axles through the sprockets and the bearings over the axles. This is of course 100x easier if the tubes are not attached to the robot already.
If you are using 2 sprockets in the middle like we do we have a small piece of axle that we'll put through the two sprockets to hold them together during the drop and push that piece out with the final axle.
