Re: Team 4592 Offseason Drivetrain
In terms of the chain, you may want to design this for the compatibility of both, it's a good designing standard for first iterations to have a backup plan, it would suck to make this and realize it doesn't work like planned. Also, you can use this calculator to get close to a perfect tension, I know 118 used this method last year. http://www.botlanta.org/converters/d.../sprocket.html |
Unless your sponsor has a break that is less than ~1" tall (min distance between bearing plates) and can extend 4" (height from bellypan to top of tube) into a piece, they cannot bend that piece.
If you make the side "tubes" that the bearings sit in two separate pieces and overlapped them at the top and bottom, it would work. See Robowranglers' X009 Design Log. Otherwise, looking pretty good. Just make sure that you leave space to get the sprockets and chain inside that side rail for installation and maintenance (I would make a hole in the belly pan in front of and behind the tube). |
Also for FRC, you should add around 0.017 - 0.019" to your C-C distance due to manufacturing tolerances on the sprockets and chain. See this thread: http://www.chiefdelphi.com/forums/sh...4&postcount=26 |
The important trick for sheet metal is understanding what your manufacturer can do. Talk to them and figure out what they can and can not do. It wouldn't be a bad idea to show them this cad and ask for feedback on it. (although, they will probably ask you break that channel into two separate parts)
Looks good!
Are those side "pontoons" each one large piece? If so, the sheet-metal bending may be touch to accomplish. It is tricky to get a die into such a tall "U" section. If these do get bent, you may find it is a struggle keep bearing holes aligned axially between the inside/outside of these U's. The belly pan lightening pattern isn't very efficient. Is this being laser cut? Turret punched? You can potentially save a lot more weight out of it -- either by moving to a more "traditional" truss pattern, or just adding additional holes and/or smaller holes within your current pattern. I'm always a big fan of the front/back angles. How tall is the frame? Depending on wheel/gearbox config, it looks like you could tighten it up a bit. Good start -- keep iterating! Each one will get better. |
The short vertical surface at each end of the belly pan may be difficult to make, depending on the sheet metal brake available to you. The design with both ends bent up means that the belly pan and the pontoons must be made to match very closely or the parts will not fit. It may be better to make the two ends as separate (identical) pieces as Chris has already suggested. The end pieces can be riveted onto the flat bottom piece. You may want to manufacture the parts so that there are only holes on the ends or on the flat middle part then match drill and rivet so that it all self-adjusts for the real-world manufacturing tolerances. As most of the other people answering you have said, you need to get know what your sheet metal supplier is capable of and design around that. The Mechanical Designers where I work do this as a matter of course. |
#7
#25 we have not figured it out for #35 yet.
#9
Any resources out there of how to calculate it?
#10
We did it by testing it on actual #25 chain. The same process from the linked thread could be used on a #35 chain setup.
#11
Paul Copioli has a chain calculator out there that had a 0.018" addition for #25 and 0.012" for #35.
http://www.chiefdelphi.com/media/papers/3166 |
