Go to Post I guess the freshmen had to learn the hard way, never turn your back on a robot. - Bcahn836 [more]
Unread 01-12-2015, 23:08
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: paper: Analysis of “a torque-actuated module” used for strafing in an H-drive.
Originally Posted by nuclearnerd View Post
I'm still not sure I would prefer a torque-actuated design over the same thing with an air cylinder pushing down, but I guess this would be useful if you don't otherwise have a compressor on the robot.
Brendan,
I would certainly be far more comfortable doing one now that I understand how it works than a week ago when it seemed like voodoo. One of the key takeaways is that this must be a gear-based system; using belts or chains, the forces would not push the wheel into the carpet with the same authority. I have not bothered yet to prove to myself that belt or chain systems cannot work, but I am confident that it would be a lot trickier at best, and would not be surprised to learn that it is impossible.
