Go to Post The most important things for a team to take to any competition are a sense of humor, a big bottle of Advil, and a camera! - Rick TYler [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 01-12-2015, 23:43
jkoritzinsky jkoritzinsky is offline
AKA: Jeremy Koritzinsky
FRC #4786 (Nicolet F.E.A.R.)
jkoritzinsky will become famous soon enoughjkoritzinsky will become famous soon enough
SuperScouter For FRC -- A Multiplatform, Extensible Scouting System
I mentioned over in a thread in the Programming forum that I was developing a multi-platform scouting system and I was asked to do a quick write-up on it. Now that I've gotten everything basically working (just needs some polishing and icon work), I've got some time to write about it:
What is SuperScouter?
SuperScouter is a scouting platform that supports iOS, Android, and Windows Phone. The server component currently is Windows only, but that may change in the future.
What makes SuperScouter "Super"?
Unlike every other scouting app, SuperScouter was designed from the ground up to support "customizable schemas". That means that each team can create a "schema" using the Schema Designer on the server application that defines what data to collect. This makes SuperScouter unique in that it does not require a brand new app each year. This allows development to focus on adding new features instead of re-creating the same thing each year.
How do the apps communicate with the server?
Schema Downloading
Schema downloading is only supported over HTTP. The application has a built in HTTP server that you can start with the "Start HTTP Server" button. It will be available on all IP addresses the server computer has. In the app, go to "Manage Schemas > Add New" and type in the IP address of the computer as given on the server app. Your schemas should show up. Tap one and tap the download button to download it. You will now be able to enter data with this schema.
Sending Data
Sending data to the server is currently only supported over HTTP, but I am working on supporting file exporting and/or Bluetooth depending on the platform.
What types of data are supported?
  • Numbers (Integers)
  • Text boxes
  • Sliders (Integers between Min and Max values)
  • Yes/No switches
  • Multiple Choice (Multi or Single select)
More (such as images support) will come.
Technical Aspects
This platform is developed entirely in C#. I am utilizing Xamarin Forms to develop my UI for all three mobile platforms simultaneously. Communication is done with Protocol Buffers since they are compact and have a simple way to support inheritance within the serialization (because of shared code). Additionally, it allows me to program the deserialization just so that it matches contract.
Cool! When will this be available?
I plan to have a version available on the respective App Stores and for download/install from somewhere (probably GitHub or something) before Kickoff.
I have a question.
Awesome! Just reply here and I'll try to get back to you as soon as I see it!
General Roadmap
  • Image data items
  • Auto-syncing with FMS API (if connectivity permits)
  • Cross-Platform Server Application
Nicolet F.E.A.R. (Team 4786) - Aerial Assist - Programming Manager
Nicolet F.E.A.R. (Team 4786) - 2015+ - Junior Mentor
SuperScouter for FRC Developer
[IMG] code is Off
