Re: Mounting New Radio
If you leave the status lights exposed, I suppose you could mount the velcro on the smooth top instead of the bottom. Attached are photos of how we tried mounting it this way when it was being gang tested with a 5v switch. It's too unsteady for competition use though. We just wanted easy access to the ports and easy visibility of the status lights. The slightly rounded top worked better with an extra piece of double-sided tape under the "wings" so to speak.
We zip-tied and velcro strapped ours on when it was used in off-season competition matches. I think for competition we might go with a 3d printed open sleeve emphasizing removability, ventilation, status light visibility, and port/power access. Last edited by Mark McLeod : 02-12-2015 at 11:53. |
Yeah, this is what I would like too.
Sounds like a challenge for CAD students to put their skills to use before the season starts. I look forward to seeing the many ideas that result.
How well did that TRENDnet switch work for you? Were there any issues with it at all? It seems like a good choice for adding additional ports.
It couples nicely with the radio and one shared VRM, since the radio takes from the 12v side and the switch takes from the 5v side. |
