Go to Post Grease, blood and cookies... it must be build season. - danshaffer [more]
Unread 02-12-2015, 16:14
bmammen's Avatar
bmammen bmammen is offline
AKA: Brent Mammen
FRC #5801 (Inspire)
bmammen is an unknown quantity at this point
Re: Swerve and Steer Module
Originally Posted by Peyton Yeung View Post
I made a small flat plate from aluminum (2" x 1.5") to mount an MA3 encoder and a 20t gear to make the steering 1:1.
Do you happen to have any pictures of the plate with the encoder/gear mounted to it? We're still trying to figure out how we want to handle the absolute encoders.
Unread 02-12-2015, 22:16
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
Here are some pictures of the setup.
The encoder has a 1/4" output so I took a 3/8" hex shaft, drilled a 1/4" hole in one end, slotted the hole with a band saw, and slid a shaft collar over the slot and voila. The encoder now has a 3/8" hex shaft which I coupled with a 3/8" hex gear with the same number of teeth so the feedback is 1:1. The whole plate has just 5 holes in it.
461 Westside Boiler Invasion
45 Technokats
Unread 03-12-2015, 12:56
We also added a 1:1 encoder gearing, but 3d printed the gears. We were looking for a smaller footprint.
Unread 03-12-2015, 19:47
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
Thanks for mentioning us in your post Peyton! Yes, we had quite a bit of success with these modules this year. We also used the US Digital MA3 absolute encoders for wheel direction. The mechanical solution mentioned earlier is fine if you are OK with always setting up in the same orientation and don't care about putting one more task on the drive team. We chose not to do that, and our different auto routines ran best with different initial wheel orientations.
My only observation on these modules is that after a bit, the gears begin to chatter. The shaft with bevel gear can flex away from its mating gear on the wheel and result in slipped gears. We still did well with it. It also allowed us to get going with swerve very quickly. But I must also shout out to Apple Pi. Without their Labview swerve code, we would have had a really rough time.
Unread 03-12-2015, 21:30
page2067's Avatar
page2067 page2067 is offline
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
We were psyched to hear that a team that did as well as you guys used our code as a basis.
Congratulations on a great year!
Our programming team will be posting our past year swerve update later this fall. Our code and some powerpoint that describes the basis for it are on our resource tab of our website.
We appreciate hearing from teams that find it useful.
Unread 04-12-2015, 12:20
bmammen's Avatar
AKA: Brent Mammen
FRC #5801 (Inspire)
It was very useful to our team! We look forward to checking out the update code when you get it posted as well. Thanks
Unread 13-12-2015, 19:58
bmammen's Avatar
AKA: Brent Mammen
FRC #5801 (Inspire)
Any idea when you might post last seasons code? Curious what changes you guys made, your bot was very smooth on the field!
Unread 04-12-2015, 14:46
page2067's Avatar
AKA: rick page
Mark:
Curious - how much backlash or wiggle does the steering have before the steering encoder feels it?
Unread 04-12-2015, 17:57
Mark:
There is nearly none between the steering motor gear through the plastic encoder gearing. There is some normal backlash between the metal-to-metal steering gear and the wheel module gear. I should mention that these swerve units were constructed based on the AndyMark design, but were not purchased units, so play in through the mechanism may be different than in the commercial units.
I'd need to test again for more exact measurement. I don't remember the original numbers, but they aren't anything that affects the operation.
Unread 04-12-2015, 12:15
bmammen's Avatar
AKA: Brent Mammen
FRC #5801 (Inspire)
That may be the simplest solution I've seen so far, thank you so much for the information and pictures! We would also like to give a shout out to Apple PI for the great LabView code they created for Swerve, our programmers were able to use it for the base code on our off season bot.
Unread 13-12-2015, 20:18
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
So the 3/8" hex shaft acts like a collet clamping onto the encoder shaft? That's a pretty neat set up!
CAMS Robotics, FIRST Team 687 The Nerd Herd 2010-Present
College Mentor 2013-Present // Design Chairman 2012-2013
Berkeley High Robotics, FIRST Team 5499 2014-Present
College Mentor 2014-Present
