Go to Post Good tooling doesn't cost money, it makes money (and prevents doctor visits). - travis [more]
Unread 07-09-2015, 07:59
ArthurA's Avatar
ArthurA ArthurA is offline
I think that I'm registered???
FRC #4774 (The DropBears)
ArthurA has a spectacular aura aboutArthurA has a spectacular aura about
Swerve and Steer Module
So my team is considering buying four Andymark Swerve and Steer modules modules so we can develop a swerve drive platform that can be adadapted to different games due to a modular design. Does anybody have any experience with this platform? If so, my main questions are:
1. Is it any good as a swerve drive?
2. Do parts break easily?
3. Are parts easy to replace? If one breaks, do you have to buy a new one?
4. Any other infro you have on this, or videos of it in action?
Thanks in advance
Unread 07-09-2015, 09:38
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
Re: Swerve and Steer Module
Originally Posted by ArthurA View Post
So my team is considering buying four Andymark Swerve and Steer modules modules so we can develop a swerve drive platform that can be adapted to different games due to a modular design. Does anybody have any experience with this platform? If so, my main questions are:
4. Any other info you have on this, or videos of it in action?
Thanks in advance
1. I like the fact that the module is all in one. I bought 3 for testing this summer and I quite enjoy them.
2. I only had 1 part break break on me and that was due to my assembly error with the arbor press and a bearing.
3. Many of the components of the module can be purchased individually. For example I broke the housing in the press and was able to buy a new one for pretty cheap.
4. A couple of teams found success this year with a swerve and steer platform.
461 Westside Boiler Invasion
45 Technokats
Unread 07-09-2015, 09:56
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
The one downside is the absolute encoder is not 1:1 on the steering module. There are several ways to deal with this, a quick search here should yield some potentional solutions to this issue.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 07-09-2015, 10:36
Knufire Knufire is offline
There is an alignment feature; a hole in the top plate that is cocentric with a hole in the top plate of the rotating part of the module with the thrust washer. This allows you to stick an allen wrench through both for an easy way to align the wheels in the same position. Making sure they're aligned whenever you reboot the robot should let you use incremental quadrature encoders without much of an issue.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 07-09-2015, 11:09
bmammen's Avatar
bmammen bmammen is offline
AKA: Brent Mammen
FRC #5801 (Inspire)
bmammen is an unknown quantity at this point
AndyMark mentioned they would have a fix for this sometime in September, but haven't heard if they're on track with that or not.
Unread 07-09-2015, 12:41
45 Alumni
AKA: Peyton Yeung
I made a small flat plate from aluminum (2" x 1.5") to mount an MA3 encoder and a 20t gear to make the steering 1:1.
45 Technokats
Unread 02-12-2015, 16:14
bmammen's Avatar
AKA: Brent Mammen
FRC #5801 (Inspire)
Do you happen to have any pictures of the plate with the encoder/gear mounted to it? We're still trying to figure out how we want to handle the absolute encoders.
Unread 02-12-2015, 22:16
45 Alumni
AKA: Peyton Yeung
Here are some pictures of the setup.
The encoder has a 1/4" output so I took a 3/8" hex shaft, drilled a 1/4" hole in one end, slotted the hole with a band saw, and slid a shaft collar over the slot and voila. The encoder now has a 3/8" hex shaft which I coupled with a 3/8" hex gear with the same number of teeth so the feedback is 1:1. The whole plate has just 5 holes in it.
45 Technokats
Unread 03-12-2015, 12:56
We also added a 1:1 encoder gearing, but 3d printed the gears. We were looking for a smaller footprint.
Unread 03-12-2015, 19:47
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
Thanks for mentioning us in your post Peyton! Yes, we had quite a bit of success with these modules this year. We also used the US Digital MA3 absolute encoders for wheel direction. The mechanical solution mentioned earlier is fine if you are OK with always setting up in the same orientation and don't care about putting one more task on the drive team. We chose not to do that, and our different auto routines ran best with different initial wheel orientations.
My only observation on these modules is that after a bit, the gears begin to chatter. The shaft with bevel gear can flex away from its mating gear on the wheel and result in slipped gears. We still did well with it. It also allowed us to get going with swerve very quickly. But I must also shout out to Apple Pi. Without their Labview swerve code, we would have had a really rough time.
Unread 03-12-2015, 21:30
page2067's Avatar
page2067 page2067 is online now
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
We were psyched to hear that a team that did as well as you guys used our code as a basis.
Congratulations on a great year!
Our programming team will be posting our past year swerve update later this fall. Our code and some powerpoint that describes the basis for it are on our resource tab of our website.
We appreciate hearing from teams that find it useful.
Unread 04-12-2015, 12:15
bmammen's Avatar
AKA: Brent Mammen
FRC #5801 (Inspire)
That may be the simplest solution I've seen so far, thank you so much for the information and pictures! We would also like to give a shout out to Apple PI for the great LabView code they created for Swerve, our programmers were able to use it for the base code on our off season bot.
Unread 04-12-2015, 12:20
bmammen's Avatar
AKA: Brent Mammen
FRC #5801 (Inspire)
It was very useful to our team! We look forward to checking out the update code when you get it posted as well. Thanks
Unread 04-12-2015, 14:46
page2067's Avatar
AKA: rick page
Mark:
Curious - how much backlash or wiggle does the steering have before the steering encoder feels it?
Unread 04-12-2015, 17:57
Mark:
There is nearly none between the steering motor gear through the plastic encoder gearing. There is some normal backlash between the metal-to-metal steering gear and the wheel module gear. I should mention that these swerve units were constructed based on the AndyMark design, but were not purchased units, so play in through the mechanism may be different than in the commercial units.
I'd need to test again for more exact measurement. I don't remember the original numbers, but they aren't anything that affects the operation.
