Go to Post Mess up something important and you lose. Just like real life. - DonRotolo [more]
Unread 02-12-2015, 18:33
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Throttle Motor
Due to the gearbox design, there are many possibilities on how to power the motor. We have found spade connectors to be the most effective method of supplying power. These fit through the holes on the front of the gearbox, but the pins can also be bent at 90 degrees to supply power from the sides. Soldering wire directly onto the power pins works great too.
