Go to Post Wow I am old. How did that happen? - Paul Copioli [more]
View Poll Results: What is your favorite feature of the SD540?
Light Weight 25 20.33%
Low Cost 47 38.21%
Multi-Bank Option 31 25.20%
I do not like this product. 47 38.21%
Multiple Choice Poll. Voters: 123. You may not vote on this poll
  #61   Spotlight this post!
Unread 02-12-2015, 14:50
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
Re: SD540 Motor Controller
Originally Posted by techhelpbb View Post
Do you have a particular drive train like that in mind?
If you do I have 2 of these speed controls and a lot of spare parts.
Depending on what you have in mind I may have everything required.
full FRC weight (154lbs with bumpers and battery) plaction (or similar) wheels at around 10fps. That's about the worse I've seen at a competition. A test both with and without fans would also be interesting if you don't mind.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
  #62   Spotlight this post!
Unread 02-12-2015, 14:56
philso philso is offline
FRC #2587
Originally Posted by Scott Kozutsky View Post
full FRC weight (154lbs with bumpers and battery) placation (or similar) wheels at around 10fps. That's about the worse I've seen at a competition. A test both with and without fans would also be interesting if you don't mind.
That sounds more realistic.
Do you have a way to monitor or measure the temperature of the heatsinks?
  #63   Spotlight this post!
Unread 02-12-2015, 15:39
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Do you have a protocol for this?
  #64   Spotlight this post!
Unread 02-12-2015, 17:44
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Does it really matter if it has bumpers if it is the proper weight?
I have 4", 6" and 8" AndyMark plaction wheels: I assume 4"?
I'll likely stick with the keyed shafts as I only have a limited amount of hex shaft and bearings.
What distance between the wheels (frame dimension)?
What configuration of the wheels: center drop with 6 wheels all driven with chain?
Fans are no problem I have fans and a CFM meter somewhere.
I have a lot of ways I can measure and log temperature.
What sort of resolution are you after?
Anyone care if a cRIO is used as the control system for this test?
I'll use the FRC approved master breaker and the FRC PDB that came with the cRIO if I do that.
  #65   Spotlight this post!
Unread 02-12-2015, 17:49
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
He was just saying that 154lbs is the actual max FRC Robot weight. Some people might think they should test at 120lbs since that is the weight limit but they would be forgetting the 34lbs from bumpers and battery.
  #66   Spotlight this post!
Unread 02-12-2015, 17:50
techhelpbb's Avatar
I've got plenty of exercise weights I can toss on there.
  #67   Spotlight this post!
Unread 02-12-2015, 18:34
FRC #2587
Most safety standards state that parts that can be touched (i.e. the heatsink) should remain below 65 to 75 degrees C. With approximately a 25 degree C ambient temperature, those numbers will also leave plenty of thermal margin for most electronic parts such that their lifetime is acceptable (in the range of years).
One would want to see the temperature stabilize for some reasonable period of time. Considering the small thermal mass of the heatsink on this controller, a 2-3 degree range over 5 minutes seems reasonable. It certainly should not still be showing an upward trend as in the data published by Mindsensors. In our lab at work, we stop the tests after there is less than 1 degree C of variation over an hour but that is not realistic here with a robot that is constantly in motion and a load that is not held constant.
  #68   Spotlight this post!
Unread 02-12-2015, 20:41
James Kuszmaul James Kuszmaul is offline
NEFIRST CSA
FRC #0971 (Spartan Robotics)
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
Is there any data on all this floating around somewhere for existing motor controllers? Obviously, we know that the existing victors and talons work fine, but it would be interesting to see the data from the new controllers compared to an existing one rather than seeing numbers thrown out without any intuitive scale.
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
  #69   Spotlight this post!
Unread 02-12-2015, 22:53
techhelpbb's Avatar
Single stage and single CIM AndyMark Stackerbox with a 3.57:1 ratio feeding a 12 tooth double sprocket which is #35 chain driving a 26 tooth sprocket on the AndyMark 4" plaction tires. Arranged as a 6 wheel center drop with the gear box on one end and the other end driving 1:1 off the center axle. Sounds like that's just over 10.1fps to me but I am pretty tired right now.
That meet your expectations?
I've got the double sprockets and the #35 chain with link kits.
I've got 10 single stage Stackerboxes.
I -may- have some 26 tooth sprockets on some used tires if not I'll need to order those.
I've got some sprocket spacers for the AndyMark tires.
  #70   Spotlight this post!
Unread 03-12-2015, 00:43
FRC #0865
If you really want to go overboard on these controllers go 4 wheel, your choice. Otherwise looks absolutely fine to me. Realistically there will be more variance in "aggressive" driving than from any individual design choice.
  #71   Spotlight this post!
Unread 03-12-2015, 06:43
techhelpbb's Avatar
To be clear, since I described one side of a potential drive train, when you proposed going even further with 4 wheel you would end up with a robot with 8 wheels total. 4 on the floor at any one time and 2 elevated at each end.
I agree that the driving style is very important and I only have 3 pairs of 4" AndyMark plaction tires, 12 bearings of the 20 I have on hand, and need to order sprockets because I only have 4x 24 tooth sprockets on my 8" used mechanum wheels.
So there's going to be a short blocking delay while I wait for the few little parts I need to do this with just 6 4" wheels total. I am not entirely blocked because I can still start putting things together.
Frame dimensions or wheel spacing?
  #72   Spotlight this post!
Unread 03-12-2015, 13:42
FRC #0865
I meant 4wd total (2 per side-more turning scrub=more motor work). Honestly the number of wheels isn't that important. Just use whatever you have on hand.
  #73   Spotlight this post!
Unread 03-12-2015, 15:04
techhelpbb's Avatar
I will emulate an AndyMark wheel spacing and frame. Thinking about ways to rig the frame so it can drive on 4 or 6.
Aside from that: 8 wheel with 4 down has as much scrub as 4 wheels plus additional chains and losses but I agree it is just a bit more than necessary to test this.
  #74   Spotlight this post!
Unread 04-12-2015, 18:46
techhelpbb's Avatar
Consecutive posts because of the time between them:
Orders for the few missing pieces have been placed.
I will start some assembly this weekend.
  #75   Spotlight this post!
Unread 08-12-2015, 22:12
talon540's Avatar
talon540 talon540 is offline
Talon 540
FRC #0540 (Talon 540 Godwin Robotics)
talon540 will become famous soon enough
Re: SD540 Motor Controller (**VIDEO**)
In Talon 540's workshop, we shot a short video of our robot running with SD540's, which you can view here: http://youtu.be/9lq6U3EpyTg
There are a total of six SD540 motor controllers on this robot: four for the mecanum wheels, one for the lift, and one for the pneumatic pump.
They worked like a charm! Our team highly suggests you switch to SD540's for the 2016 season competition and onward! The manufacturer, mindsensors, has their main web page at: http://www.mindsensors.com/
