Go to Post Even as a "mentor", I am still being mentored by engineers who work with the team. - Tom Bottiglieri [more]
Unread 02-12-2015, 08:52
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Re: pic: WCD off season chassis from 2471
Got it - thanks.
Are those 3" x 0.875" wheels? How are they kept from slipping off the hex shaft?
Unread 02-12-2015, 10:23
Nate Laverdure's Avatar
FRC #2363
Originally Posted by RobotsThatWork View Post
Two 16 tooth vexpro sprockets do not sit next to each other inside the 2x1x1/8 (so width). This is true for both when bearings are press-fitted, and when I use a versa bearing block. The Sprocket with Chain attached to it has a total diameter of 0.491 inches. When I put 2 back to back it would be too wide to fit inside the boxtubing. Any solutions?
We chose to avoid this problem by using 2 x 1.5 x 1/8 tube.
The 17t sprocket works in the 2 x 1 x 1/8 because it has a large enough pitch diameter that the chain clears the 1.125 bearing OD.
Unread 02-12-2015, 12:37
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Originally Posted by pribusin View Post
Got it - thanks.
External retaining rings: http://www.mcmaster.com/#97633a200/=102dny4
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 02-12-2015, 12:48
Nebster's Avatar
Nebster Nebster is offline
AKA: Ben Kishter
FRC #1306 (BadgerBOTS)
Nebster is an unknown quantity at this point
What are you using to hold the corners of the frame together? It's not clear to me
2015 Wisconsin Regional Chairman's Award - Carson Division
2013 Wisconsin Regional Chairman's Award - Curie Division
Unread 02-12-2015, 12:52
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
There are blocks in the ladders with through bolts going through the rails.
Unread 02-12-2015, 13:00
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
http://www.team221.com/order.php?cat=15
See "Chassis Tube Connector"
Unread 02-12-2015, 14:46
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
This was a point of much discussion while in the design phase. We thought gussets would be stronger, but using blocks would fit with the chain in tube solution better.
This is what we ended up going with, partly because the belly pan is adding a lot of corner to corner strength already.
We did not use these, but they look to be functionally equivalent. The plastic blocks ended up being a good project for younger students to get some training and experience in.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 02-12-2015, 16:01
cxcad cxcad is offline
FRC #1683 (Techno Titans)
cxcad will become famous soon enoughcxcad will become famous soon enough
It would be interesting to see the FEA for the block vs gusset design. On my team the thought was that blocks were stronger because the blocks were pulling the frame members toward each other.
Unread 02-12-2015, 21:48
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
Does anyone know where to find a cad file for this?
The half inch hex
Unread 02-12-2015, 23:24
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
The half inch hex
Because I couldn't find it, I just downloaded the round version, put a hex bore in it, re-saved it as a STEP file, and reopened it. That gave me the 1/2" hex 17t double sprocket.
Unread 03-12-2015, 19:20
zinthorne's Avatar
AKA: Avery
I can not find the round version. Am I missing something on the website?
Unread 03-12-2015, 19:42
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
I emailed them about it last year. The file can be found here.
Unread 03-12-2015, 22:42
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
Wait, Mean Machine's not doing swerve?
Glad to see you're having fun and building robustly for BunnyBots -- should be a fun event.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
Unread 04-12-2015, 17:43
Nebster's Avatar
AKA: Ben Kishter
What are you doing for center drop? Do the sprockets you're using inside the tube have enough clearance with the walls of the tubing for a center drop? I haven't seen that done before but since you're using 1/16" tubing it could be possible.
Do you feel 1/16" walled tubing is strong enough for a traditional drive train?
Unread 04-12-2015, 18:06
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Yep, I'm looking forward to it!
The bearing blocks we are using have their bearing holes drilled 1/16" off center. The center wheel has its block upside down compared to the outer wheels, so that gives us 0.125" drop. If it tips around too much or is too squirrely, we will flip one of the outside wheels for effectivly a 0.0625" drop. We are using 16t #25 chain sprockets.
I think so, but we'll know for sure by the end of the month.
Anything that survives this BunnBot game will certainly be "strong enough for a traditional drive train"
