Go to Post I hate to do say it with these words but...We're all in this together. - dellagd [more]
Unread 02-12-2015, 17:45
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
Wheel Spacing Ratios
I have seen a couple of these discussions pop up lately:
http://www.chiefdelphi.com/forums/sh...d.php?t=139936
http://www.chiefdelphi.com/forums/sh...d.php?t=139171
Past discussions:
http://www.chiefdelphi.com/forums/sh...ad.php?t=86443
http://www.chiefdelphi.com/forums/sh...d.php?t=129521
http://www.chiefdelphi.com/forums/sh...d.php?t=116836
There are a few white papers and calculators out for this is well. I wanted to take a more simplistic approach to this and just look at wheel spacing ratios.
Assumptions:
- All wheels are loaded and spaced evenly
- 6 wheel no drop has 2/3 effective length of 4 wheel
- 6 wheel drop has 1/2 the effective length of 4 wheel
- 8 wheel 2 center drop has 1/3 the effective length of 4 wheel
It seems the KOP drive is as good of standard as any in FIRST, which has had a 1.8 width to length ratio over the years. The current no drop KOP wide configuration has around a 2.5 with the 2/3 effective length of the 6 wheels. The drive in a day (DIAD) from vex appears to be around a 2.3 width to length ratio, but they have a few patterns to choose from.
Is the 1.8 number an acceptable minimum for width to length wheel contact patches?
Should there be a maximum width to length ratio?
Does center drop matter with length? (the opposite wheel clearance is twice the drop distance)
Unread 02-12-2015, 22:09
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
Re: Wheel Spacing Ratios
I don't think it's accurate to assume that the center wheels in a 6wd center drop are equally loaded. The center of mass is usually much closer to the center than either side of the robot and usually the center wheels take substantially more load (tread wear makes this very apparent). This means that teams can run quite substantially longer than the optimal ratio would suggest on a 6wd drop (see 2056 in 2013).
Aside from that nitpick this is a well done analysis. Please label your graphs better though. It's hard to interpret a graph and spreadsheet of two unitless values where one of which isn't properly labeled.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 02-12-2015, 22:51
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I'm not really sure where your numbers are coming from; are you assuming a certain length, width, or frame perimeter as constant, and what are you varying to get the different categories?
The KoP chassis does have a drop center, and can be constructed to several different lengths, which as I understand it, would change your numbers considerably.
The bottom lines as far as I can see are that:
  • For most solid tire materials, the track to "effective length" must be significantly greater than 1.0 to turn (1.25 to 1.50 are good enough for most purposes, 1.8 is rather high).
  • The center drop must be enough that you can only have significant weight on two axles. Longer robots with softer (pneumatic or sponge) wheels on soft carpet will require more drop than a robot with a shorter wheelbase, solid wheels, or which drives on firm carpet.
Unread 02-12-2015, 23:27
Deke's Avatar
no team (No Team)
Agreed, its really CoG dependent. This is more of a worst case scenario of centered weight on 4 of the 6 wheels.
The middle row is a square configuration for wheel contact of the outermost wheels (1.00 W/L for 4 wheels). The 4wd is the baseline, and the other wheel configurations are calculated based on the assumptions. They are unit less.
Unread 03-12-2015, 00:25
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
For those of us who don't know, would someone mind explaining what a Wheel Spacing Ratio is and why it's relevant/important?
I'm also not entirely sure what I'm looking at on that chart, some additional labels would be nice imo.
Unread 03-12-2015, 06:09
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I'm not sure I've seen this term before, but the idea seems to be the effective aspect ratio of the wheels which contact the carpet. A 4 wheel "tank drive" vehicle with normal (non-holonomic) wheels which is longer than it is wide will be unable to rotate or turn while driving because the lateral friction of the wheel on the carpet can generate more torque resisting the turn than the rolling friction can in creating the turn. This lateral friction is known as "scrub".
However, making all robots "wide" isn't effective either, as they tend to fall over backwards in hard acceleration or forwards in hard braking. The "drop center" drive is designed to give the best of both situations; a long wheel base for purposes of acceleration, and a short wheel base for purposes of turning (because the wheels which do not contact the carpet don't count, and wheels which carry less than their "fair share" of the weight count less than those which do when it comes to generating the scrub torque.
Yes. I'm not sure what "the assumptions" were to generate the rows, either.
Unread 03-12-2015, 07:15
Deke's Avatar
no team (No Team)
Nicely worded, yes you are correct.
I have edited the post with reference lengths and axis labels.
Unread 03-12-2015, 07:34
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
This classic CD whitepaper is a worthwhile read.
The terms "track" and "wheelbase" are also worth the time it will take to look them up.
Richard Wallace
since 2003
Unread 03-12-2015, 19:53
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Great whitepaper, or GREATEST whitepaper?
Everyone should read.
Unread 03-12-2015, 21:13
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
*Digression. Hopefully this won't derail the thread too much.*
Speaking of things that should be read, is there any chance your old blog will come back at some point?
CAMS Robotics, FIRST Team 687 The Nerd Herd 2010-Present
College Mentor 2013-Present // Design Chairman 2012-2013
Berkeley High Robotics, FIRST Team 5499 2014-Present
College Mentor 2014-Present
