Re: Mounting Grayhill Encoders On Rookie Transmissions
The kit transmission last year was a toughbox mini. The CIMple box was last in the kit in 2012.
On our custom WCD for this offseason, Grayhills 63Rs were were loosely pressed into the inside ends of the rear axles and the encoder housing was secured (so it won't spin with the axle) by zip tying the signal wires to the frame (method found here on Chief Delphi).
I admit I am not familiar with the KOP drive train, but it might be easier to figure out how to mount them on the outer live axles instead of to the transmission? For the method I described above all you really need is a 1/4" hole at the center of one of the other live axles. |
My mistake. I just meant the outer axles.
The 2013 KOP gearbox was a flat-plate Toughbox mini. CIMple boxes were last issued as part of the KOP drivetrain in 2012.
