Go to Post I never wanted to be a teacher. This was the year I learned that I am one. It turns out mentors are teachers. Oops. - marshall [more]
Unread 02-12-2015, 23:07
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Mounting Grayhill Encoders On Rookie Transmissions
Sorry I am not 100% certain which single speed AM transmissions the rookies got in their kit last year.
I am guessing it was http://www.andymark.com/CIMplebox-p/am-0734.htm
Anyone tried adapting a standard 63R Grayhill encoder to it ? Hard, easy ? Is there enough room between the cims ?
Our rookie team wants to use Grayhills if possible. Unfortunately we don't own the transmission.
Thanks
Unread 02-12-2015, 23:30
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Re: Mounting Grayhill Encoders On Rookie Transmissions
The kit transmission last year was a toughbox mini. The CIMple box was last in the kit in 2012.
461 Westside Boiler Invasion
45 Technokats
Unread 02-12-2015, 23:47
Kenny Cheung Kenny Cheung is offline
FRC #0008 (Team 8)
Kenny Cheung is an unknown quantity at this point
On our custom WCD for this offseason, Grayhills 63Rs were were loosely pressed into the inside ends of the rear axles and the encoder housing was secured (so it won't spin with the axle) by zip tying the signal wires to the frame (method found here on Chief Delphi).
I admit I am not familiar with the KOP drive train, but it might be easier to figure out how to mount them on the outer live axles instead of to the transmission? For the method I described above all you really need is a 1/4" hole at the center of one of the other live axles.
Unread 02-12-2015, 23:57
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
The 2013 KOP gearbox was a flat-plate Toughbox mini. CIMple boxes were last issued as part of the KOP drivetrain in 2012.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 03-12-2015, 04:36
Knufire Knufire is offline
The only live axles are the center wheel/gearbox output. The outer wheels are on dead axles.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 03-12-2015, 05:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If all you need is a 1/4" hole to mount the encoder, you can attach a 1/4" shaft coupler to the encoder stub at the back end of the main output shaft. We've done this in the past with a potentiometer when we were making a TB-mini into a super-sized servo to steer our t-shirt cannon.
Unread 03-12-2015, 15:00
FRC #0008 (Team 8)
My mistake. I just meant the outer axles.
Unread 04-12-2015, 05:19
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Thanks
Dave, don't quote me on this, because I haven't looked at the kit gearboxes in a while... but:
The AndyMark gearboxes that support the US Digital encoder right in between 2 CIMs don't have enough space to place a Grayhill in the same spot.
We've worked around this problem in the past. It's not ideal, but it actually works well - scroll down to the 4th picture:
http://www.chiefdelphi.com/forums/sh...3A#post1298264
Note that there is a wood dowel inside the surgical tubing to prevent it from collapsing and twisting. There is nothing holding our custom plastic mount in place other than the tension from the surgical tubing, and the curved sides that match the profile of the CIMs. You can take the encoder off by just pulling straight back, and stretching the tubing.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 08-12-2015, 15:42
de_ de_ is offline
AKA: Dave Edwards
Thanks everyone for the input
Shawn, exactly what I was afraid of
