Go to Post It is amazing how much a person's participation in FIRST can shape his/her character. - Jupee [more]
Unread 02-12-2015, 15:54
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
Re: Mounting New Radio
We do the same thing as what Mark McLeod said. We Velcro it on the top for two reasons:
1- The feet aren't in the way
2- The PIN is still visible for when need to configure a new network
SolidWorks CAD
AutoCAD
Java
Unread 02-12-2015, 16:29
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Funny guy, right here.
Brian K
Team 1225 Robotics Mentor
Unread 02-12-2015, 16:34
Originally Posted by feverittm View Post
... the version that is currently being tested by the Beta test teams is a 12V units and not 5V as it was in previous years.
Something I did was make sure to flag each barrel connector with the voltage it is carrying and the device it is to provide power to. I also flag the positive wire with a red flag at the VRM end to lessen the chance of a miswire there.
Originally Posted by billbo911 View Post
How well did that TRENDnet switch work for you? Were there any issues with it at all? It seems like a good choice for adding additional ports.
I haven't had any issues with it. It's nice and light.
It couples nicely with the radio and one shared VRM, since the radio takes from the 12v side and the switch takes from the 5v side.
Unread 02-12-2015, 16:47
Alicia V Alicia V is offline
FRC #2046 (Bear Metal)
Team Role: Electrical
Alicia V is an unknown quantity at this point
Does anyone know if there are new guidelines for the radio? Is there any part of it that need to be visible for inspection?
We had a slot for the previous radio that was similar to a phone case- a polycarbonate frame with Velcro on the inside. I'm thinking we could do the same with this one but put Velcro on the front and possibly the bottom to hold it in place, the problem with this is the location of the ports.
If anyone makes a CAD for mounting it, please post.
Unread 02-12-2015, 16:56
Make the status indicators visible from the side of the field when you mount the radio.
The power and Ethernet ports at one end are nice for the field staff to be able to see from close up when troubleshooting, too, but they don't have to be visible from far away like the status lights.
There isn't anything else to see on the sides or bottom, but they do have ventilation slots that should get some air exposure, but also be protected from metal dust and shards.
The antennas used are along the sides, so keep those away from close contact with metal and with a clear line of sight outside the robot.
Unread 02-12-2015, 22:34
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
How tall are those feet?
In the past, we've used Scotch/3m Duallock fasteners to hold our radios down. We've had occasional trouble getting the duallock to stick to our control board or the modem, but not to each other. When we've cleaned plastic surfaces (e.g. with alcohol) prior to use, we've done pretty well. Duallock is nearly 1/4" thick when engaged. If that's not enough, a fairly light spacer (such as a piece currogated plastic sign board) in the mix should be able to fill the gap.
Unread 02-12-2015, 22:43
Are the feet big enough to stick a decent-sized piece of Velcro or similar onto?
Can the feet be removed safely (and legally--but that part will have to wait until next season)?
Unread 03-12-2015, 07:36
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Picture of the feet:
http://team358.org/files/programming...Radio-back.jpg
You can remove the little black rubber widgets but I wouldn't modify the plastic housing... or maybe I would... I haven't decided what we're going to do yet.
They are tall enough that engagement of velcro on a flat surface is not ideal. A spacer is a good idea.
EDIT: Removed duallock hypothesis since Mark says that it is a no-go below.
Unread 03-12-2015, 07:37
The feet are 4 millimeters or 5/32".
It's the same spacing as one side of 3M Dual-lock to the tips of the hooks, so a spacer would be necessary. The side of dual-lock can be easily slid under the radio when it's sitting flat on a table with no snagging.
Remember too that there are ventilation slots covering most of the bottom that I'd be loath to completely cover, especially with fuzzy insulation.
I personally like to be able to still see the critical parts of the labeling-power specs, MAC address.
Last edited by Mark McLeod : 03-12-2015 at 08:06. Reason: "No" rather than "slight" snagging
Unread 03-12-2015, 08:12
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Originally Posted by marshall View Post
Now that I've seen it, why not use those key-shaped mounting holes? Two pan-head bolts with spacers behind should be able to engage them, then just add a bracket to keep it from sliding towards letting them out the keyholes. (top in photo). It looks like there's a 3" spacing, so we may be good to go on pegboard without drilling.
Unread 03-12-2015, 08:49
marshall's Avatar
Also a good idea.
Unread 03-12-2015, 17:50
The two mounting holes are 2 5/8" apart center-to-center.
A pan head 5/16" in diameter fits.
Unread 03-12-2015, 23:34
PayneTrain's Avatar
PayneTrain PayneTrain is offline
no
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Dual-Lock and a velcro strap would get you 100% of the way there but if you want to make a 3D printed sleeve and post it on the internet for me to steal that works.
