Go to Post You can take the man out of FIRST, but you can't take FIRST out of the man. - George1902 [more]
Unread 02-09-2015, 12:36
logank013's Avatar
logank013 logank013 is offline
System.out.println("Ready!");
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
Re: "Black Box" Electrical Board
So in 2014, we had a "roll cage" like thing for our electronics. It was held down by 4 allen bolts so it was fairly easy to take off. It was a see through blue and was made of some sort of plastic (I don't know what type since I'm on electronics and didn't make the box). If I remember right, it only protected the cRio and a few other small things. I don't think it protected the talons or victors. I believe it is still on our bot so I can take a picture of it tonight if you want me to. I take it this "black box" is to protect your electronics?
P.S. I'm not sure if it was ever used in a competition. I'm pretty sure it was, but I joined in the 2015 season.
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
Unread 28-11-2015, 10:13
Danimal!'s Avatar
Danimal! Danimal! is offline
FRC #4118 (Roaring Riptide)
Danimal! is on a distinguished road
After a wiring nightmare from the previous year, our team made an electronics box. We made side mounts for 45 Amp powerpole (Anderson) connectors. This allowed the box to be detachable. We added vents and fans to the box to help with cooling, but in general, heating was not an issue. Like some of the previous posters mentioned, you want to make sure that you have easy visual access to the status LEDs. We didn't have any issues with passing inspection. In fact, most of the inspectors appreciated the effort the team made to make the wiring as clean as possible. I recommend building a prototype of the box in the off-season. We built a prototype last summer, learned a ton, and then redesigned the box we used in the 2015 season from scratch using everything that we learned. Here are the CAD files that we used for 2015 box, the prototype, and our 2015 bot (so you can see how it attached to the robot).
http://riptiderobotics.com/resources/cad/
It's a lot of work, but the effort pays off. In roughly 40 matches, our 2015 bot had zero electrical issues.
Unread 28-11-2015, 11:30
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Originally Posted by GeeTwo View Post
We always wait until we have at least a rough robot design before we start on the control board. The past two years, having a relatively large, flat control board worked well (belly pan, under the ball in 2014 Aerial Assist, and on the rear and low, but easily accessible for 2015 Recycle Rush). For AA, we arranged so the taller cRIO was to one side and the large parts of the pneumatics system were in the corners where they would not interfere with the ball. For RR, the roboRIO was low-profile, and we did not use any pneumatics.
In short, design your control board like you design your robot -- for example, if you make advance plans for three or four basic drive systems, make advance plans for three or four basic control layouts. Then, wait until you've done your game analysis, strategy selection, and at least high-level robot design before you do your control system physical design.
These are very important things to keep in mind. Take it from someone who was given the task of CADing the entire control system while the mechanical side of the robot was still being designed- don't waste your tine designing something that seems really good when your specs are going to change in a couple days. It's not worth the 3 weeks of headaches and late nights.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 03-12-2015, 08:28
Danimal!'s Avatar
I found a website that will host 3D models that can be manipulated in your browser. Here is the electronics box that 4118 designed last season.
https://skfb.ly/ITCp
Unread 03-12-2015, 08:42
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
You can also try grabcad.com. Its a lot more commonly used and also automatically does file sharing and version control.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 03-12-2015, 09:41
Noudvanbrunscho's Avatar
Noudvanbrunscho Noudvanbrunscho is offline
Scout mentor
FRC #4481
Noudvanbrunscho is a jewel in the roughNoudvanbrunscho is a jewel in the roughNoudvanbrunscho is a jewel in the rough
http://teamrembrandts.com/archieven/2269?fb_ref=Default
Here is our 360 view of our 'Black Box' from last year, we made it very compact and easy to take out of the robot.
2015 - Team Spirit Award (Tesla-Archimedes Division)
2015 - Engineering Inspiration (Virginia)
2015 - Finalist (Virginia)
2014 - Imagery Award (Newton Division)
2014 - Engineering Inspiration (North-Carolina)
2013 - Rookie All-Star (North-Carolina)
Forty fooouuuuurrrr --- Eighty ooooooonnnnneeee!
Unread 03-12-2015, 09:44
philso philso is offline
FRC #2587
The relatively tight packaging constraints one has to work with in FRC robots make designing after your spec is understood an imperative.
Congratulations on the significant improvement in reliability! Please be clear though. This increase in reliability was more likely due to greater thought and care being given to the layout and construction than the fact that your control system was enclosed in a box. Since putting in place a better construction standard that includes verifying the quality of all connections (crimps) we have had only one electrical failure in the last two years. That failure was a loose crimp in an old battery cable.
