Go to Post H.A.T.E.R.S. = Having Anger Towards Everyone Reaching Success - pandamonium [more]
Unread 02-12-2015, 13:30
lewislongbottom's Avatar
lewislongbottom lewislongbottom is offline
Klein Bots 3735 Mentor
FRC #3735
lewislongbottom is on a distinguished road
pic: Klein Bots 3735 2015 Offseason Drivetrain Project CAD Rendering
Unread 02-12-2015, 13:33
kyle_hamblett's Avatar
kyle_hamblett kyle_hamblett is offline
Hamby
FRC #1073 (The Force Team)
kyle_hamblett will become famous soon enoughkyle_hamblett will become famous soon enough
Re: pic: Klein Bots 3735 2015 Offseason Drivetrain Project CAD Rendering
Looks nice! It looks like 148 was a bit of an inspiration (correct me if I'm wrong). Does it use chain-in-tube or are the chains just not shown?
Unread 02-12-2015, 13:40
FRC #3735
This offseason, the Klein Bots decided to design a WCD Chain-In Tube drivetrain. We wanted to experiment with different options and features, so we went with a modular design strategy.
We wanted to have a versatile drive-base configuration; so we now have options to test an 8WD, 6WD, and 4WD drivetrain just by changing the configuration of the drive-tubes.
We also have pockets in the bellypan to move the position of the gearboxes; which are the VexPro 2 CIM Ball Shifters, this function just gives us more options if we decide to change positions to accommodate different drive configs.
We also designed what we call the "Wings", they were inspired by FRC Team 148 on their experimental drivetrains. We aren't getting these fabricated right now, this will be a future addition (hopefully).
This will be our first WCD (and Chain-In Tube) so we hope to learn some things before the coming build-season if we do decide to go ahead with this design.
Unread 02-12-2015, 14:48
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
What type of wheel drop do you plan on running?
Unread 02-12-2015, 15:07
FRC #3735
We don't have a drop in the CAD, however I believe the plan is to use traction wheels and rivet an extra layer of tread on top of the existing tread. It should give us enough lift on the center wheels to avoid wheel scrub.
Unread 02-12-2015, 15:12
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Just be careful: that means the edge of your center wheels will be moving faster than the edge of your outside wheels. This could cause some weird driving experiences as the bot "rocks" slightly, putting more weight on the front, back, or center wheels.
Also, what are the giant holes in your bellypan for? Is there a mechanism being designed to go there?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 02-12-2015, 15:15
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Several other teams are currently doing this already. The speed difference tends to be negligible.
Unread 02-12-2015, 15:16
FRC #3735
We will keep that in mind.
"We also have pockets in the bellypan to move the position of the gearboxes; which are the VexPro 2 CIM Ball Shifters, this function just gives us more options if we decide to change positions to accommodate different drive configs."
Unread 02-12-2015, 16:06
FRC #2451 (Pwnage)
I'm curious about the short length verses wide width when the center wheels are touching the carpet but the outside wheels aren't. During acceleration the four back wheels are the only ones touching and that scares me also. Our experience is that this makes for a twitchy bot when turning and an unstable bot when trying to drive fast in a straight line. Anyone have experience with this?
Unread 03-12-2015, 06:40
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
AKA: Tim W
FRC #0343 (Metal in Motion)
fargus111111111 is on a distinguished road
Why not go with omniwheels on the corners so that there is no need for a drop. It seems like that would result in a more stable robot than any drop center and it eliminates the need for different diameter wheels.
Unread 03-12-2015, 07:38
Flywheel Police
Teams have been running 8WD robots in this configuration for years without issue. The same could be said about 6WD drop center robots only running on 4 wheels at a time and yet it is probably the most popular setup in FRC.
Unread 03-12-2015, 08:47
Jay Burnett Jay Burnett is offline
FRC #5332 (Toaster Tech)
Jay Burnett is an unknown quantity at this point
Just for thought's sake, what would be the trade-offs of switching the 4 corner wheels out for omnis? Did you guys think about doing this at all? And if so, why did you decide against omnis?
Unread 03-12-2015, 08:59
Flywheel Police
I believe you'd be lowering the amount of traction you have because you'd be taking some of the weight off of the center traction wheels and moving it to the omni wheels.
Unread 03-12-2015, 12:12
Everett33's Avatar
Everett33 Everett33 is offline
AKA: Everett Owen
FRC #2145 (HAZMAT)
Everett33 is on a distinguished road
Is there a reduction between the gearbox output shaft and the wheels, or is a direct drive? If it is a direct drive, using the JVN Spreadsheet gives this chassis an adjusted speed of 20.5 ft/s, which is extremely fast.
I walk the pits of FIM and take cool robot photos.
•Lead Driver 2009-2013 •Mechanical Mentor 2014-2015
•Record of 6-2
Unread 03-12-2015, 12:39
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Good catch the 2 CIM Ballshifters are normally used with a third stage when doing a west coast style direct drive setup.
