paper: Analysis of “a torque-actuated module” used for strafing in an H-drive.
Thread created automatically to discuss a document in CD-Media.
Analysis of “a torque-actuated module” used for strafing in an H-drive. by GeeTwo |
Re: paper: Analysis of “a torque-actuated module” used for strafing in an H-drive.
I'll look at this more in-depth during the weekend, but just wondering, should there be some part of the equation that would involve the torque coming from the motor... or is my brain too focused on the upcoming finals week to physics?
The key to an elegant solution to a physics problem is finding the right system to analyze, and the right coordinate system to perform the analysis. The torque coming from the motor feeds in to this via D. The results I found here seem to indicate that if you have "too much torque", you don't get wheels spinning out against the floor, but rather the module continuing down and lifting the robot (presumably until the module rotates past 90 degrees, when it will eventually spin freely in the air). Of course, many modules will be designed with "stops" to keep this from happening, which will introduce a considerable force not accounted for in my analysis.
As an example of an inelegant solution, one of my earlier attempts found me proving through a number of trigonometric identities that: Quote:
Thanks Gus. It's nice to have an analysis of this module done up - it really speeds up the design process
I'm still not sure I would prefer a torque-actuated design over the same thing with an air cylinder pushing down, but I guess this would be useful if you don't otherwise have a compressor on the robot. |
I would certainly be far more comfortable doing one now that I understand how it works than a week ago when it seemed like voodoo. One of the key takeaways is that this must be a gear-based system; using belts or chains, the forces would not push the wheel into the carpet with the same authority. I have not bothered yet to prove to myself that belt or chain systems cannot work, but I am confident that it would be a lot trickier at best, and would not be surprised to learn that it is impossible. |
Is this assuming a value of θ that's fairly close to 90°? For small values of θ, it seems like assumption 1 for the B force no longer holds - the primary limitation on the normal force will come from the lever action of the module.
Here's my derivation for small values of θ:
F = τ*ρ/Rwheel Fmax = μ*N N = τ/Rmoment*cos(θ) Law of cosines: Rmoment = sqrt(Rwheel^2+Rlever^2-2*Rwheel*Rlever*cos(90+θ)) = sqrt(Rwheel^2+Rlever^2+2*Rwheel*Rlever*sin(θ)) In order for the wheel not to slip, F <= Fmax Thus, τ*ρ/Rwheel <= μ*τ/Rmoment*cos(θ) ρ <= μ*Rwheel/Rmoment*cos(θ) ρ <= μ*Rwheel*cos(θ)/sqrt(Rwheel^2+Rlever^2+2*Rwheel*Rlever*sin(θ)) |
#7
As you note, for small θ, the term deriving from B (the one with tan θ) is much less important than the term deriving from D (the one with sec θ). |
#8
I think I follow now. However, it seems to me that you're missing a term in equation 3: the force on the module by the pivot axle's bearings. Without this, you have forces at the wheel pushing up and force at the interface between the gears pushing down (from the frame of reference of the module), so there's an unresolved torque moment that will cause the module to rotate counterclockwise.
#9
![]() There are reaction forces on both ends of the beam, and the sum of all three force must be 0. I see this as the same case here: the beam is the module, one end is supported by the wheel bearings (and transitively by the wheel on the carpet), the other end is supported by the the bearings on the drive axle. I think you have to separate the two, because only the part of the force that's being experienced at the wheel is ending up as normal force. ------ I'm not sure if this is the correct analysis, but as a general point, I'm bothered that your derivation doesn't incorporate the distance between the drive axle and the wheel axle. If you increase this distance, then the torque load on the motor imposed by turning the wheel won't increase, but the torque load imposed by the normal force does. At some point, turning the wheel will be much easier for the motor than applying normal force, so the wheel will spin with very little normal force applied, causing the wheel to slip and the robot won't move. |
#11
Either: - analyze it from a force perspective, where you have to consider all 3 forces (D, reactive force from wheel axle bearings, reactive force from drive axle bearings), or - analyze it from a torque perspective, which allows you to choose your origin so that r*F is 0 for one of the forces, but you have to include the radius for the other two |
#13
In my physics classes, we were always told that the first step of solving a mechanics problem is to define your system. Forces between bodies in the system are internal forces and must sum to 0, because both halves of the force pairs are included. Forces from bodies outside the system acting on those inside the system are external forces. Since the internal forces sum to 0, then the external forces make up the Fnet as used to calculate Newton's 2nd law, Fnet = m*a. My interpretation of your paper was that the system being considered consists of
If we take a fairly idealized version of the problem, the external interactions are the following contact and frictional forces:
Equation 3 accounts for the last three, but not the first, unless you can present an argument that the first force is completely parallel to B. Did I misinterpret your paper? Did you use a different system definition when doing your analysis? Last edited by RyanCahoon : 12-08-2015 at 08:00 PM. |
#15
