Go to Post "PWMed" - Sam N. [more]
Unread 03-12-2015, 18:51
simon1636 simon1636 is offline
FRC #4501
simon1636 is an unknown quantity at this point
Spike Code Problems
Hi! My robotics class is using cRIO FRC 2014 on Netbeans with Java. The code we are using does not seem to work. We are coding a Spike relay as a kind of intake system, yet each time we upload it to try and control it, nothing happens! If any of you could take a look at the code to see if you notice any problems that would be great! Thanks!
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.GenericHID;
import edu.wpi.first.wpilibj.Relay;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.Timer;
public class RobotTemplate extends SimpleRobot {
    RobotDrive myDrive;
    Joystick moveStick, rotateStick;
    Talon backRight, backLeft, frontRight, frontLeft;
    Relay relay;
    public void robotInit(){
                frontLeft = new Talon(1);
                backLeft = new Talon(2);
                backRight = new Talon(3);
                frontRight = new Talon(4);
                relay=new Relay(1);
                //myDrive = new RobotDrive(frontLeft, backLeft, frontRight, backRight);
                myDrive = new RobotDrive(backLeft, backRight, frontLeft, frontRight);
                moveStick = new Joystick(2);
		rotateStick = new Joystick(1);
     * This function is called once each time the robot enters autonomous mode.
     * This function is called once each time the robot enters operator control.
    public void operatorControl() {
        //while(true &&isOperatorControl() &&isEnabled()){
        //myDrive.setInvertedMotor(RobotDrive.MotorType.kRearRight, true);
        //myDrive.setInvertedMotor(RobotDrive.MotorType.kRearLeft, true);
        while (isOperatorControl() && isEnabled()) {
            myDrive.mecanumDrive_Cartesian(moveStick.getY(), rotateStick.getX(), moveStick.getX(), 0);
        if (rotateStick.getTrigger(GenericHID.Hand.kLeft)&& isEnabled()){
            relay.set(Relay.Value.kOff);
            relay.setDirection(Relay.Direction.kForward);
                    //mecanumDrive_Polar(moveStick.getY(), moveStick.getX(), rotateStick.getX());
           Timer.delay(0.1);
     * This function is called once each time the robot enters test mode.
