Go to Post *be there or be triangle, circle, square - PVCpirate [more]
Unread 13-11-2015, 22:51
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
FRC Team CC is an unknown quantity at this point
[FTC]: OTG Cable from ZTE phone to Core Power Module Doesn't Work
Hey Chief Delphi,
We are the Charging Champions, FTC Team 8660 from SoCal. Last week, when we were testing our drive train on the ramp, our robot fell backwards and the OTG cable that connected the ZTE phone to the Core Power Module broke. We bought a replacement cable on Amazon (http://www.amazon.com/StarTech-com-M...dp/B008635BA2). The ends of the cable fit into the ports but the phone did not seem to recognize the connection as the configuration on the Robot Controller phone did not detect that there were any motor controllers plugged in.
Are the ZTE phone and the Core Power Module not compatible with third-party cables? If it is compatible, what else could be causing the issue? Thanks in advance.
Thanks,
The Charging Champions
FTC Team #8660
Facebook Page: https://www.facebook.com/chargingchampions
Follow us on Twitter: @FtcTeamCC
Google Plus: https://plus.google.com/112552147224383900922/posts
Youtube channel: https://www.youtube.com/channel/UCop...G3zsvQKCXF4ESQ
Blog: http://chargingchampionsblog.blogspot.com/
Unread 14-11-2015, 07:22
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Re: [FTC]: OTG Cable from ZTE phone to Core Power Module
The cable you linked to at Amazon does not say "OTG". I see the Modern Robotics Inc. cables are out of stock. I don't see the mini to micro OTG cable on Amazon. The OTG micro to female "A" connector: SANOXY Micro USB OTG (On-The-Go) to USB 2.0 Adapter with an additional USB "A" to mini might work: USB 2.0 - Mini-USB to USB
Ebay has cables that look like the right configuration: search "micro USB B to mini USB B otg"
Unread 14-11-2015, 12:05
Sasha Sasha is offline
AKA: Alexander Kirillov
FTC #4137 (IslandBots)
Sasha is just really niceSasha is just really niceSasha is just really niceSasha is just really niceSasha is just really nice
This one works - we tested it.
http://www.amazon.com/gp/product/B00MWQBN24
FTC 4137 "Islandbots"
islandbots.org
Unread 14-11-2015, 13:03
Thanks for the quick response. We will buy the cables.
FTC Team #8660
Unread 16-11-2015, 15:08
mjc49's Avatar
mjc49 mjc49 is online now
Coach - Team 3042
AKA: Mike
FRC #3042 (Cobalt Catalyst)
mjc49 is an unknown quantity at this point
I also appreciate the reference. After competing this past weekend there was some 'overly enthusiastic' attempts to secure the cable and I want to replace our teams cables. Knowing this one has successfully worked for someone helps a lot.
(2013-Current) Coach-Team 3042 Cobalt Catalyst, MN North Star Regional Winners (2014 w/2177 & 4778, 2016 w/2175 & 3130)
2017 - LRI: MN North Star Regional
Unread 04-12-2015, 09:52
COG_8924's Avatar
COG_8924 COG_8924 is offline
FTC 8924 Center of Gravity All Girl
FTC #8924 (Center of Gracity)
COG_8924 is an unknown quantity at this point
Don't buy these cables, didnt work for us
Link
Unread 06-12-2015, 19:02
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
We finally competed yesterday in league play here in Chicago with about 12 teams present for the first set of matches.
Despite our having continuous problems with phone disconnects relating to USB communications both over the last few weeks since our bot has been driving, as well as in several of our matches, we still ended up in first place.
I have heard that there were certain early release Modern Robotics electronic modules that had know issues that triggered frequent disconnects. we are talking to them to see if we have these buggy modules. Meanwhile, I am looking at the problem of our use of many either too stiff, too long (heavy) or too short USB cables on our bot.
I know that the 3d printed strain relief frames are out there, but I would prefer to minimize as much of the source(s) of this stress in the 1st place. To that end, I have been searching for premium USB cables with much higher flexibility (thinner cable). There are some USB cables available marketed for robotics and rated for millions of flex cycles, rather than thousands, but I have not found any "micro" plug size from that source.
This a German company "Hama" has this nice thin cable in micro plug size, but no U.S. distribution that I can find.
Hama brand "Flexi-Slim" Micro USB OTG Adapter Cable, gold-plated, red, 0.15 m
Has anyone else been investigating sources for more suitable cables engineered specifically for robotics duty, expecially ones with right angle options?
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 07-12-2015, 13:07
MattRain MattRain is online now
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
You are highly unlikely to find a USB cable that wont need some strain relief. The problem is within the MR module. The port in which the cord plugs into is too high off of the module, which means any type of USB will be hanging out, and will cause the MR Port, and ware a lot quicker. A simple, less than .03 cent piece, whether it be a 3d Printed part, Piece of wood, or screw, can save you so much heart-ache, pain, and time.
https://twitter.com/trojans8640/stat...10567272099841
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
