Go to Post At the end of the day, and this is where many may disagree, it's about what is learnt and not about who wins. - popnbrown [more]
Unread 30-11-2015, 08:52
Billfred's Avatar
Billfred Billfred is offline
Re: Buying Pneumatic Rivet Gun
2815 had the Harbor Freight gun the last year I worked with them. Worked like a champ once we figured out the oil situation and installed the right items into our air supply, though we still used our hand riveter a good bit due to some tight spaces caused by using angle aluminum as a gusset rather than flat plates. These days, less of an issue.
Unread 30-11-2015, 09:11
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The translation of the rivet gun's operation manual from Chinese to English leaves a lot to be desired. It is not hydraulic in the traditional sense of using oil as a working fluid. It uses oil for lubrication. A few drops of light machine oil in the air inlet occasionally for lubrication is all that is need. No disassembly required. I use 3 in 1 oil.
Unread 30-11-2015, 09:57
lewislongbottom's Avatar
lewislongbottom lewislongbottom is offline
Klein Bots 3735 Mentor
FRC #3735
lewislongbottom is on a distinguished road
Yeah, you have to use the wrench that comes with it. Also bench vices' can be handy if you need a third hand!
Unread 02-12-2015, 11:57
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Originally Posted by mman1506 View Post
The only issue we've had with the gun is the nose breaking off when it was dropped (our fault). I went on a trip to the US just to buy another.
I considered doing that as a gift to my new team but ordered this from Amazon.ca instead. It was $71 back in June when I ordered it, probably cost about the same or better than the HF after you factor in exchange and gas.
Allstar ALL18207
http://www.amazon.ca/dp/B003BZQ6MW/
Unread 02-12-2015, 16:14
DonShaw DonShaw is offline
FRC #1261
DonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of light
Just because you have 90psi does not mean you have enough flow(volume)to operate a pneumatic air tool. You need to look at the CFM on the compressor and air tool to make sure you have the volume.
Unread 02-12-2015, 19:08
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Well I sure hope that we have the CFM . We are running it off the same air supply that we are running our shops CNC plasma.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 02-12-2015, 19:24
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
You should be fine, a CNC plasma uses far more flow than a rivet gun.
2016: FRC 865 Mentor
Unread 02-12-2015, 19:38
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The crappiest air compressor you could buy is gonna be fine. a rivet gun should be like a fraction of 1 CFM. All those 5 gallon pancake compressors that people tend to have are at least 2-2.5 CFM.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-12-2015, 19:48
Munchskull's Avatar
Team Role: CAD
That's what I was getting at.
I have not actually seen the compressor but based on the fact that it supplies our metals shop, auto shop and jewelry lab I have a feeling it is pretty big.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 05-12-2015, 04:10
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
We use the Campbell Hausfeld one. Had it 3 or 4 years now. No complaints. Gets the job done.
Can I power this rivet gun with an old (large) 12v. FRC compressor?
Dave
Unread 05-12-2015, 09:23
mman1506's Avatar
no team (WARP7)
Dave
I've run it off our robot's pneumatic system a couple of times at competition. You will just need to add a couple air tanks and you should be fine.
Unread 05-12-2015, 10:03
FRC #1261
So here are the specs on the Northern gun, it takes much more air than one would think.
Specs
Item# 15761
Manufacturer's Warranty 12 months parts / 12 months labor
Ship Weight 6.0 lbs
Application Rivet tool
Working Pressure (PSI) 80–100
Rivet Size (in.) 3/16
Air Consumption (CFM) 4.2
Air Inlet Size (in. NPT) 1/4
Max. PSI 80
Additional Information
Parts List
One of the most important things to remember when dealing with pneumatic's is the volume of air required. The students on our team have had a hard time grasping this as well.
When looking at the specs this would make one of those "Crappiest Pancake compressors" below the specs needed to operate.
Boyles Law is a great thing to know when working with pneumatics
Unread 05-12-2015, 11:17
mman1506's Avatar
no team (WARP7)
Specs
Item# 15761
Ship Weight 6.0 lbs
Max. PSI 80
Parts List
I don't think the CFM requirements are really as high as the instructions entail. I have the absolute crappiest compressor you can buy, rated at .7 CFM at 90 PSI (I think it was even worse in reality) and it was easily able to keep up with normal riveting work. Our robot's air system was also easily able to keep up with 4 air tanks attached.
Unread 05-12-2015, 14:41
Cory's Avatar
AKA: Cory McBride
Specs
Item# 15761
Ship Weight 6.0 lbs
Max. PSI 80
I have a really difficult time believing that rating is accurate. the Campbell Hausfeld one is likely identical to the Northern Tool one and any other similar appearance/price rivet gun and it is rated for 0.2 CFM.
I know the real world rating of a couple other things that are 2 and 4 CFM respectively and the volume of air being moved through them at 90 PSI is wayyyyyy more than a rivet gun.
2001-2004: Team 100
Unread 05-12-2015, 17:44
Michael Hill's Avatar
Possibly an instantaneous CFM? The duty cycle of a pneumatic riveter is generally pretty dang low. Though I have no idea why they would even put that on the label.
