Go to Post So, we should have respect for each other regardless of whether we are building our robot with a Waterjet or a Hacksaw. Construction methods will vary widely, but honoring your competitors should be universal. - OZ_341 [more]
Unread 05-12-2015, 21:35
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: 2823 Offseason WCD Test Chassis
Originally Posted by BrendanB View Post
Keeping the ends of your tubes open is a plus. If not, consider attaching the front/back tubes & bellypan with bolts for cleaner access. Rivets can be faster to drill out and replace compared to a bolt/nut but having the variable of aluminum shavings flying around your robot in the middle of a crisis repair isn't worth the few seconds in most cases. 3467 ran a Chain in Tube running our elevator last year (the layout was identical to a 6wd setup like this one) and having the ends open made the single repair/adjustment we made to the chains after assembly not as painful. Someone (*cough* me *cough*) accidentally pulled the center output shaft on the practice robot.
Did you consider rivnuts or other captive nuts? When combined with a cordless screwdriver and the appropriate bit, this could be just as quick to remove and replace as a rivet -- without the shavings and need to keep a big stock of fasteners in the pit.
