Go to Post There will be violence next year! YAY! - Koko Ed [more]
Unread 06-12-2015, 22:01
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Re: HSM Express+Tormach undersized holes
If it's thin as aluminum foil, it is likely just the variation in the material wall thickness. As suggested, machine to a lower depth.
I wouldn't be too worried about the thin layer if it happens again. Poke it with a punch and run a deburring tool to trim the leftover and you'll be fine.
Edit: I missed the bottom height offset. That will work as well.
Now, test out some higher speeds and feeds and post some videos of the tests!
Unread 06-12-2015, 22:28
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Bottom offset is the setting you want. Just make sure you get the sign right.
Unread 07-12-2015, 08:42
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
On the first question, I'd be willing to bet your running a roughing process for the bearing hole and it needs a finishing process to remove the remaining material.
In the second scenario, I've experienced this quite a bit on my tormach. I would either use a deburring tool to remove the foil, or set my zero for the Z axis a tad bit lower than actual zero. This happens sometimes based on how the workpiece is clamped down, which can cause the material to bow in the center, or pick up on one end.
Unread 07-12-2015, 13:50
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Maybe this is a function of how HSMExpress works, but I don't really understand why this is even a problem. Aren't you hand entering a depth to cut to? Or is it selecting that depth based on the depth of the chain you selected?
If it's the former, just put in -.1875 or -.250 for a .125" wall thickness tube.
2001-2004: Team 100
2006-Present: Team 254
Unread 07-12-2015, 14:41
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
HSMExpress selects the depth of cut based on the contour/profile you select. So, if the part being milled is modeled with a wall thickness of .125", but in reality has a wall thickness of .127", in a perfect world, the milling operation leaves .002" of aluminum at the bottom of the hole.
What I have found is that if I just set the "Bottom Height Offset" to a value of .010", then the end mill will extend .010" beyond the selected profile. This will cut the hole cleanly as long as the material being milled is less than .010" thicker than the expected .125".
Unread 07-12-2015, 14:57
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Odd when I use MasterCAM for solidworks it does a similar thing by picking the depth of the chain selected. But like Cory I just over write the value and add .125 more to the depth. Especially in tubing. Is this not an option in hsm?
R.C.
MadTown Robotics Team 1323
Unread 07-12-2015, 15:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Chains? Haha, you MasterCAM folks are funny.
Unread 07-12-2015, 15:24
protoserge's Avatar
It should be covered with the "Bottom Height Offset" option.
Unread 07-12-2015, 15:39
Cory's Avatar
AKA: Cory McBride
It's still a chain, even if it's selecting the feature.
2001-2004: Team 100
Unread 07-12-2015, 16:39
Jared's Avatar
Jared Jared is offline
I like to create a few planes in SW model for depths/clearance heights and set the toolpath to use those planes, rather than entering a bunch of offsets. This way I only have to figure out depth and clearance/retract plane locations once. The default clearance plane is a little excessive.
For depth, I would try to go as deep as possible. You'll get more rigidity and you'll use the part of the end mill that's likely used less, so you'll get more tool life.
HSMWorks calls them contours.
