Go to Post I don't remember who said it or what the words are exactly...(I think it was Hopalong Cassidy) Don't say goodbye, just say see you later. - Al Skierkiewicz [more]
Unread 06-12-2015, 23:58
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: New Product Line (Competition Robot Parts)
I like the concept of the press-in hubs for rollers, that seems like a useful product for any year where we deal with intake mechanisms. Still might be tricky for a lot of low-resource teams to find a press to actually assemble them though, since you wouldn't be able to fit a reasonably sized roller into a vise. You'd need a stand up press or some fancy jerry-rigging.
Unread 07-12-2015, 00:01
AdamHeard's Avatar
Lead Mentor
We've used threaded rod, nuts and washers with good success. Had to use some oil because we were just using random hardware, if we planned ahead a brass or bronze nut would've helped a lot.
We've used the above technique with a hole drilled in our hydraulic cart to use it as a pull press for installing long lengths of tubing in plastic tubes. Fun stuff.
Unread 07-12-2015, 00:14
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
A cheap harbor freight arbor press clamped between two tables would probably work. I've used that setup for numerous things.
Unread 07-12-2015, 09:35
pfreivald's Avatar
AKA: Patrick Freivald
Are the hubs press fit? What's the tolerance? Have they been tested for torque application, or are they intended as idlers only?
If you're pressing them in, how do you make sure the hexes are aligned on both sides?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 07-12-2015, 09:57
Chris is me's Avatar
AKA: Pinecone
Two ways you can do this: Either put a bearing in one side and a hub in the other, or press one side in, use a hex shaft with a collar on the end to pilot the other side, and press the whole thing down.
Unread 08-12-2015, 22:47
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Yes, they are a press fit. The ID of the tubing is 1.120in and the body of the end cap is 1.125in. That results in a .0025in interference (nominally) all the way around.
I have not tested these for maximum torque but I've used this fit on robots before with no issues.
Thanks for your time,
Orion DeYoe
FRC Team 2252 "The Mavericks" 2011-2014 (Student)
FRC Team 5413 "Stellar Robotics" 2014-???? (Mentor)
2011: Drive Coach, CAD, Programming, Electrical
2012: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2013: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2014: Drive Coach, Strategy, CAD
2015: Team Founder, Design/CAD Mentor, Drive Coach
Unread 08-12-2015, 22:49
Knufire Knufire is offline
I bought a few, and intend to use green Loctitie or just bolt through the side of the tube into a tapped hole on the hub. Better be safe than sorry.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 08-12-2015, 23:57
AdamHeard's Avatar
Lead Mentor
What's the tolerance on the tube and on the hub?
My experience with tubing is that ID is likely a .010 range minimum.
Unread 09-12-2015, 16:33
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
I like the prices of the 1"-wide brackets for frame building--lower than all of the competitors...wonder if this will drive some price reductions in the market.
Just my personal opinion, but some of the prices for other parts seem a bit high for what they are...$10 for a single roller hub?
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
