Go to Post I like to divide checklists like this into "stuff I have to do before applying power" and "stuff I'll find faster by watching it fail". - EricVanWyk [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 07-12-2015, 12:59
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Debating with physics teacher.
Originally Posted by JamesBrown View Post
Because it is important to understand why the model does not match real world results. Understanding what other forces are in play is important, even if understanding how to quantify those forces is beyond the scope of the course.
From an engineering standpoint you may be correct, but from a physics education standpoint, it is trivial and over complicates the treatment of the relationship between position, velocity and acceleration. Even when dealing with net forces I don't even deal with it. We discuss why our model breaks down when comparing real world situations, but it's not worth dealing with it even on a qualitative level. Just my opinion.
Unread 07-12-2015, 13:58
Michael Hill's Avatar
I agree...poorly worded. It really should say something about assuming they're the same shape of the same size. I read "air resistance" from a force perspective (coming from an aeronautics background). So if they're the same size and shape, the heavy rock will experience more force. You can assume they're spheres if you want (it turns out the specific shape doesn't really matter). The aerodynamic force on a sphere will be a function of shape, surface finish, and velocity. See this: https://www.grc.nasa.gov/www/K-12/ai...ragsphere.html
Because the heavier rock has a greater gravitational force, it needs a greater aerodynamic force to counteract the gravitational force (at terminal velocity). Since the aerodynamic force is greater, the velocity is greater (this is why heavier objects of the same shape have a higher terminal velocity). Since the aerodynamic force is greater, it experiences more air resistance.
Unread 07-12-2015, 14:27
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Of course you could always do it in a friction less vacuum
Unread 07-12-2015, 15:08
wilsonmw04's Avatar
Coach
It's a thing; at least in my world ;-)
