Go to Post Replay/video isnt a BAD idea, its just not a GOOD idea for FIRST. - Ashley Christine [more]
Unread 07-12-2015, 14:57
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: HSM Express+Tormach undersized holes
Originally Posted by billbo911 View Post
HSMExpress selects the depth of cut based on the contour/profile you select. So, if the part being milled is modeled with a wall thickness of .125", but in reality has a wall thickness of .127", in a perfect world, the milling operation leaves .002" of aluminum at the bottom of the hole.
What I have found is that if I just set the "Bottom Height Offset" to a value of .010", then the end mill will extend .010" beyond the selected profile. This will cut the hole cleanly as long as the material being milled is less than .010" thicker than the expected .125".
Odd when I use MasterCAM for solidworks it does a similar thing by picking the depth of the chain selected. But like Cory I just over write the value and add .125 more to the depth. Especially in tubing. Is this not an option in hsm?
R.C.
MadTown Robotics Team 1323
