Go to Post It's not about the equipment, it's about the program. - Taylor [more]
Unread 03-12-2015, 11:51
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: [Behind the Lines] Ep. 5 Mechanism Design with 118, 3847, and 973!
Originally Posted by Greg Needel View Post
It is really simple. Get a 12 volt drill with variable speed(old ones with burnt out motors are fine). Remove the motor, gearbox, chuck, etc. All you are left with is a handle with a switch and battery contacts. Wire your connector of choice to the output of the trigger (Where the motor used to be). That's it.
The advantage of this is you get the right voltage (assuming a 12 volt battery), variability in speed that is easy to control, and reversibility (without removing the wires.
Be warned, the really cheap ones can "burn up". did this with some $10 specials. It worked really well for a while then fried itself.
Thanks for the reminder that I need to make a couple new ones.
Unread 03-12-2015, 12:15
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is online now
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud of
I'm interested in learning a bit more about shooters as our team hasn't had to do anything with flywheels just yet. The wheel selection was well presented, but I just don't understand 254's robot in 2014 could fire the balls with a shooter! Considering the speeds and torques the 2012 motors ran out, it boggles me that the yoga balls could be fired with significant speed. Allen, do you have any resources pertaining to the deeper physics involved with shooters?
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 03-12-2015, 12:20
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Also like Lucian mentioned in the video adding fuses will help your prototyping and increase the safety of using these devices.
A cheap fuse holder can hold a snap action breaker too. We purchased a few of these to add to ours.
Unread 03-12-2015, 12:35
Engineering Coach
The Poofs do a great job of explaining their development process each year. Their build blog and technical binder are available on their website.
One suggestion is to go back and read some of the early season threads from previous shooter games. Each year we as a community learn a bit more.
2013 small wheel linear shooter design
for example.
Another suggestion is the behind the design series. The 2006 book is getting hard to find but it's a great read.
The Fighting Pi posted some great Behind the Design articles for a variety of awesome 2012 robots.
Unread 03-12-2015, 14:56
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Originally Posted by AllenGregoryIV View Post
Lot of teams use them, they are very easy to build. Just open up a 12v drill (118 uses 18volt drills sometimes but that's a bit risky with some motors) and remove the motor. Connect the wiries to Anderson connectors or some other quick dissconnects. This allows you to change the speed and direction of whatever motor connects to it.
We use a small makita 12 volt drill that we broke the chuck off of and a cheap 12 volt model from Walmart that we bought specifically to use for that purpose.
Awesome, thanks. I wish we didn't throw out the rest of the drill that we took the gearbox out of last year.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 07-12-2015, 22:29
arc25565 arc25565 is offline
FRC #1482 (Ghosts)
Rookie Year: 2015
arc25565 is an unknown quantity at this point
Does anyone know where I can get the power point that they used in the video as it had some great info. It was a great episode and I learned a lot, thanks!
Unread 07-12-2015, 22:37
Lead Bumper Mentor
AKA: Mike Marandola
Here
for example.
Here are a few more.
Unread 07-12-2015, 23:13
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Originally Posted by Mike Marandola View Post
Our engineering journal for the 2015 season can be found here.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 07-12-2015, 23:58
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Here's FIRST's archive:
http://www.firstinspires.org/resourc...hind-the-lines
Unread 08-12-2015, 11:03
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
I just reviewed the video again. Lucien mentioned a "magic rubber strip tape". What is that and what is it used for? Any links to where to buy it?
Thanks.
-T
Unread 08-12-2015, 11:52
Engineering Coach
Thanks.
This is from memory from a few years ago but I believe it's 3M self sealing tape. Something like this but someone from 118 can confirm it.
Unread 08-12-2015, 11:55
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
Not from 118, but can confirm that it's linerless electrical rubber tape. I took a picture of it to remember what it was when I was talking to them once, because I knew magic tape wasn't going to help me find it later.
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 08-12-2015, 11:58
AdamHeard's Avatar
Lead Mentor
Rescue Tape?
http://www.rescuetape.com/
Unread 08-12-2015, 12:04
ahartnet's Avatar
The picture I took specifically says it's rubber tape and not silicone. I can't imagine you'd need the high temp resistance (or the cost) that would go with the silicone tape.
Unread 08-12-2015, 12:08
AdamHeard's Avatar
Lead Mentor
OH! that comes in various permutations from 3M, and googling "rubber splicing tape" brings up a lot of options.
