Go to Post Earlier today, I finally saw a copy of the [WFA] essay that was submitted by my team (there will be a separate reckoning later with all those that kept this a secret from me). The narrative overwhelmed me. - dlavery [more]
Unread 07-12-2015, 12:23
Everett33's Avatar
Everett33 Everett33 is offline
AKA: Everett Owen
FRC #2145 (HAZMAT)
Everett33 is on a distinguished road
Re: pic: 2823 Offseason WCD Test Chassis
Originally Posted by GeeTwo View Post
Did you consider rivnuts or other captive nuts? When combined with a cordless screwdriver and the appropriate bit, this could be just as quick to remove and replace as a rivet -- without the shavings and need to keep a big stock of fasteners in the pit.
The problem I see is, where do you install the RivNuts in the tube to where you can still remove and replace the chassis rail internals without running into the RivNuts? If it were a rivet, you just drill out the rivet to remove the tube, which also removes the obstruction in the tube.
I walk the pits of FIM and take cool robot photos.
•Lead Driver 2009-2013 •Mechanical Mentor 2014-2015
•Record of 6-2
Unread 07-12-2015, 22:41
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
That depends on the placement of the rivnuts, really, although you make a good point; double sprockets would definitely give you trouble.
