Go to Post Age should not be a speed bump to creativity. - Greg Needel [more]
Unread 08-12-2015, 18:30
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Autodesk and FRC 2016
With the Kickoff just a few weeks away I will be checking the forum for any questions you may have.
Already we have a great discussion on the use of Autodesk Inventor and HSM 2016.
So for now, welcome from Autodesk and we look forward to working with you on FRC 2016.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 08-12-2015, 18:37
swaxman12345's Avatar
swaxman12345 swaxman12345 is offline
Team Member
AKA: Sasha Waxman
FRC #2512 (Daredevils)
Team Role: CAD
Rookie Year: 2015
swaxman12345 is an unknown quantity at this point
Smile Re: Autodesk and FRC 2016
Actually, our team has just started a CAD team this year, and so far we've managed to design most of an off-season robot that we're developing completely in Autodesk. So thank you sir, for the excellent software.
Unread 08-12-2015, 18:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I just attended Autodesk University in Las Vegas and was blown away. Another big THANK YOU AUTODESK for your support of education. You are an amazing company with a great corporate culture and fantastic software products.
We just finished installing Inventor and HSM 2016 today. We are looking forward to using the new "Inventor Connect" feature to do nightly design shares pushed to A360 and Shape Generator to optimize lightweight conponents . For anyone running Inventor 2016, make sure you get the "R3" update for these new features.
One thing I could use is a setup and usage guide for network distributed rendering using iRay in 3ds Max 2016.
Unread 08-12-2015, 19:19
Great to hear you were able to attend AU. It is a highly recommended event and adds a whole new perspective on the size of Autodesk and what it does as a company.
Good advice on the Inventor update so that you can access the new functionality.
I will check for you on the iRay question. Not my department!!
Phil Dollan
Autodesk Inc.
Unread 08-12-2015, 19:46
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
So long as you're taking questions,
I recently installed Inventor HSM, and I'm trying to use it to create and post process tool paths for a Southwest Industries (SWI) Trak K3 - 2.5 axis - Knee Mill with an A.G.E. 2 CNC controller. The support website for SWI simply says something to the effect of "Talk to your CAM software provider" when searching for post processing configuration settings.
If that information was something you could get a hold of I'd greatly appreciate it.
On a side note, I'm also going to be looking for configuration settings for an X-Carve CNC router from Inventables, but thankfully Inventables has a much more active online community that I can ask than I could for the Mill above (unless you happen to have that information easily available).
Unread 08-12-2015, 21:48
Chris,
I have spoken to the folks in Autodesk about HSM questions and they have suggested that questions such as yours be posted on the following site,
https://camforum.autodesk.com/index.php?board=3.0
Please follow up with me if you do not get an answer.
Phil Dollan
Autodesk Inc.
Unread 09-12-2015, 01:03
Gamma +'s Avatar
Gamma + Gamma + is offline
FRC #2130
Gamma + is on a distinguished road
Our team has recently placed a large emphasis on cad and using inventor to bridge the gap between prototypes and design. I have struggled to find a method of collaborating on inventor projects between different users and workstations. Autodesk Vault seems to be an excellent solution... But I am not sure where to start with incorporating it into the team. Is it possible to use without investing in a server. If so, is it reasonable to run it off of a workstation? We appreciate your support, and I hope that you could give me a few pointers as to how to get started, thanks.
Unread 09-12-2015, 08:22
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
If you can't get a working solution with one of the Autodesk software packages, check out GrabCAD. We have been using it for sharing SolidWorks drawings and documentation with our team.
Unread 09-12-2015, 09:34
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Hi Phil! Thank you for your support from AutoDesk. We have a CNC and a small CAD army this year (8 kids, 2 dedicated) so I'm looking forward to a great season! Autodesk's release of the full field was paramount to figuring out a canburglar design for champs, and it worked with marvelous speed/accuracy.
GitHub
Unread 09-12-2015, 20:13
Autodesk Vault is definitely the best solution for collaboration but does present issues in the school lab or FRC lab environment. In reference to the server, one computer (managed by the CAD manager) can act as the server and the other machines are the clients.
Autodesk A360 is an easier starting point in that it is cloud based and each team member can have their own accounts. It does provide the security of Vault and the Check In / Check Out work flow, but it is a good first step in data management.
Email me to discuss further.
Phil Dollan
Autodesk Inc.
Unread 09-12-2015, 20:15
Good news on the field. We will be doing our best to make it available immediately after Kickoff in January.
Phil Dollan
Autodesk Inc.
Unread 09-12-2015, 20:33
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
Always glad to see Autodesk's continual support.
We are thinking about switching to Fusion360 this year for FRC for a few reasons, but have a few issues with it. We want to switch because of the cloud-sharing, integrated CAM (love the waterjet CAM feature), and the direct insert from McMaster button.
My biggest concern right now is that I don't understand how to structure what are "assemblies" in Inventor. I understand that there are bodies, components, and component groups, but should I be making a new file for every part, or just every sub-assembly? It seems like Fusion is geared more towards the one-file robot, with all parts in that file. My only problem with this is that I made a, assembly (component group) and tried to export one of the pieces to make CAM for it, but it did not export correctly, and there was some messed up associations.
I would also love to have a belt/chain (pulley/sprocket) generator. Oh, and sheet metal parts.
Thanks
Unread 10-12-2015, 07:23
protoserge's Avatar
Thanks for this! Will it be in a native Inventor format or available as STEP/IGES as well?
Unread 10-12-2015, 17:44
Inventor 2016 and STEP.
Phil Dollan
Autodesk Inc.
Unread 10-12-2015, 17:55
Thanks
I was going to mention Fusion in the next few days but your question has moved that up a bit!
I worked with an FTC team mentor on using Fusion 360 or Inventor for his team. I started by modeling the base FTC robot using Tetrix parts. All parts were uploaded into my design from Inventor. Here is the public link to the frame I modeled.
http://a360.co/1GJf9sL
A major change in Fusion this year is being able to insert a subassembly into the current design. I used this a lot. It is officially called "Distributed Designs". The frame I built is fully functional. Driving one wheel drives all wheels and gears. You cannot see that in the preview, but it is true!
Sheet metal is on the road map for next year. I have seen some folks using scripts for gears, etc. but have not followed up on that.
Email me if you want to discuss this further.
Phil Dollan
Autodesk Inc.
