08-12-2015, 21:15
Technical Director
AKA: Gus Michel II
 FRC #3946 (Tiger Robotics)
Re: FRC Blog - Get Ready to Make FIRST Choices
Good haul - got everything from the top ten but the SRX and Battery.
Pri FC # Name Credits # # Total
1 fc16-005 PG71 Gearmotor With Encoder 100 2 2 200
2 fc16-029 Encoder Kit AMT103-V 10 2 2 20
3 fc16-099 Green Ring Light 10 2 2 20
4 fc16-021 Air Volume Tank, 32 cu. in... 20 4 4 80
5 fc16-102 Compressor, Model 90C 100 1 1 100
6 fc16-064 Talon SRX 100 0 1 0
7 fc16-036 12V Battery NP18-12 50 0 1 0
8 fc16-052 Lead Screw w/ Nut 20 6 6 120
9 fc16-084 1/2" Hex Shaft Collar... 10 2 2 20
10 fc16-085 1/4" x 1/4" Rigid Coupling... 10 4 6 40
