Go to Post it should not matter the gender of a person but rather their ability. - vivek16 [more]
Unread 08-12-2015, 22:08
arc25565 arc25565 is offline
FRC #1482 (Ghosts)
Rookie Year: 2015
arc25565 is an unknown quantity at this point
Intake wheel motors
What kind of motors and gearboxes would people recommend for jobs like intake wheels. We have many smaller motors like the window and fisher price motors and full size cims but nothing in between. What kind of motors and gearboxes would be a good buy for most medium power operations like intake wheels. Thanks for any assistance that you provide.
Unread 08-12-2015, 22:14
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Intake wheel motors
VersaPlanetary + BAG or MiniCIM gives a lot of flexibility in speed/ torque and mounting.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 08-12-2015, 22:15
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
For most teams I'd recommend using the versaplanetaries. Reasoning:
1. Able to quickly swap ratios from 3:1 to whatever. (Use load rating guide for your application )
2. Available with multiple output shafts.
3. Direct drive wheels
4. Easy to integrate with pulleys and sprockets.
5. Most flexible option imo out of any cots gearbox available.
6. This is what citrus does
R.C.
MadTown Robotics Team 1323
Unread 08-12-2015, 22:30
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Any 550 or 775 motor and versa planetary will work fairly well, however we've been switching over to bag motors for intakes because of their increased thermal mass that helps increase the margin for error when stalled.
I would consider a minicim overkill for an intake, especially considering the weight of the motor.
Unread 08-12-2015, 22:32
Knufire Knufire is offline
With the Banebot motors now illegal, I would recommend the AM 9015 or the VP BAG motors as the motors of choice for an intake.
Planetary gearboxes are great for this application, either the VP Versaplanetary or the Banebots P60. I've used both with great success.
If you do have the ability to make a custom gearbox, you do have the opportunity to save a bit of weight and efficiency with a small 3:1 or 4:1 spur reduction. Planetaries are great for getting a big reduction in a small space, but intakes are generally a high speed application. A great way to do this is to use 32DP pinion gears available from AM or WCP directly on the motor and using some of the aluminum gears that are targeted towards FTC: https://www.servocity.com/html/32_pi...l#.VmegwbgrJD8, and bolting them directly to the wheel.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 09-12-2015, 00:12
RoboChair's Avatar
AKA: Devin Castellucci
That's how we roll.
Versa Planetary and a hex broach, far you will roll.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 09-12-2015, 00:57
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
One of the mistakes teams commonly make is under powering intakes. If you've got an intake or conveyor belt, you want to put as much power on it as you can get away with.
Yes, the Mini CIM might be overkill -- but can you put a "price" on having a "Touch-It, Own-It" intake?
When I designed my first ever intake+conveyor mechanism in 2009, I asked one of my wiser friends for advice. He just told me: "The only trick as far as I can tell, is to throw power at it." I've never looked back...
I also agree that using a modular planetary gearbox is a good idea for this application. I can't count the number of times I've screwed up a gear ratio ("wow... this seems really slow!" or "hmmm... is it supposed to stall this easily?") and been saved by adjusting the planetary used in the design. This versatility will allow you to swap in different ratios (or motors) to tweak your design.
Your Mileage May Vary,
John
Unread 09-12-2015, 01:08
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
John
Another reason for over powering mechanisms is that the smaller motors (BAG,9015) will require more reduction than the larger motors(CIM,Mini-CIM) due to a higher free speed. This year instead of using a small motor with a VP on our intakes we could get the same output speed at the same weight by using a Mini-CIM with a single reduction. Giving us more power with less cost, weight and complexity.
2016: FRC 865 Mentor
Unread 09-12-2015, 01:25
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Anyone have any pictures of Mini-CIM intakes?
Unread 09-12-2015, 01:31
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
254 in 2013. though they started changing motors around. i forgot what they settled on for champs.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 09-12-2015, 01:33
mman1506's Avatar
no team (WARP7)
They aren't great photos but:
Here is our intake without wheels.
And a side view with wheels
Overhead
1114's intakes also use CIMs
Unread 09-12-2015, 03:54
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
I can't agree more; that approach definitely paid off for us in 2010. Our pincher intake that year was powered by a full-size CIM with a heavily torqued friction clutch (to avoid completely stalling the motor). There was sufficient current draw that we used current measurement to determine whether or not we had the ball--it consumed over 30A when it had the ball! It was hard on our batteries, but it was worth it; there were several times we simply yanked the ball out of other robot's intakes, even on Einstein (definitely "touch-it, own-it"!).
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 09-12-2015, 09:25
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Please note that fisher price motors have been illegal for a few years now... I would of recommend removing them from the shop so they don't accidentally end up on your robot!
2016: Lake Superior WFFA
Unread 09-12-2015, 10:07
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Another tip for intake wheels when it comes to selecting the right gear ratio and motors: Your "intake velocity" aka the linear speed of your intake wheels should be greater than the max speed of your drivetrain. This makes it easier for you to intake a game piece while driving at it full speed.
Unread 09-12-2015, 11:04
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The MiniCIM/CIM for Versaplanetary seems like a great way to go to get more power - except for a major factor (IMO). How do we accurately and cleanly cut the CIM/MiniCIM output shaft down to 3/8"? We once made a prototype with a MiniCIM/Versaplanetary, but wound up using standoffs from the adapter because the kids weren't able to figure it out at the time.
GitHub
