Go to Post Ship day is a sweet and sour day. You're happy to see your robot ship, but then you start going through robot withdrawl - Schneidie [more]
  #31   Spotlight this post!
Unread 08-12-2015, 16:53
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
What's the difference between it and normal electrical tape?
  #32   Spotlight this post!
Unread 08-12-2015, 17:14
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: [Behind the Lines] Ep. 5 Mechanism Design with 118, 3847, and 973!
Electrical tape is vinyl, not rubber, for what it's worth.
  #33   Spotlight this post!
Unread 08-12-2015, 17:36
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
I'm pretty sure this also doesn't have any adhesive on it. It basically only sticks to itself.
  #34   Spotlight this post!
Unread 08-12-2015, 20:36
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
It's also a lot thicker than regular electrical tape and stronger. It also has a good tacky texture to increase its coefficient of friction with most materials.
  #35   Spotlight this post!
Unread 08-12-2015, 23:08
philso philso is offline
FRC #2587
double post
  #36   Spotlight this post!
Unread 08-12-2015, 23:11
FRC #2587
It sticks to itself then fuses over time into a continuous mass. The ones I have used did not have adhesive and would stick to itself due to "tackiness".
It is also called "self amalgamating tape". It is used to create a continuous electrically insulating "coating" on objects that were not previously insulated and are inconvenient to apply insulation to using "normal methods".
A mechanic I used go to in Toronto used self amalgamating tape to replace the insulation on part of a wiring loom in my car where it had dried out and crumbled away, causing all kinds of shorts. We use the silicon type to cover up the bolted joints in the insulated bus bars, to get continuous insulation, in some of the large industrial electrical equipment built in our plant at work.
http://solutions.3m.co.uk/wps/portal...gamating-tape/
