Go to Post Life is too short to spend 40 hours a week doing something you are not enthusiastic about. - Karthik [more]
Unread 09-12-2015, 10:58
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: Racing Wheels
Originally Posted by mastachyra View Post
Yeah, having the bigger wheel helps with precision. and having other buttons attached is useful. No need to reinvent the wheel! Pun intended!
I personally don't like the idea of the buttons' positions changing as the wheel rotates, but to each his (or her) own.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 09-12-2015, 11:33
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
Re: Racing Wheels
Our team is strongly against using racing wheels to drive the robot, however I've talked to a couple teams (846 and 1538) that used racing wheels to drive their robots. From what they said, using that as a controller takes a bit of getting used to, especially if your driver is used to the simple tank layout. It's definitely worth playing out with different control schemes. Remember that just because you bought yourself a wheel doesn't mean you should necessarily use it for every single FRC game.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 09-12-2015, 11:53
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
Re: Racing Wheels
Originally Posted by Andrew Schreiber View Post
Someone should tell that to 16...
Or 971
Team 1318: 2011-2015
Team 1747: 2015-Present
NAR (VEX U): 2015-Present
Unread 09-12-2015, 14:49
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Racing Wheels
I'm pretty convinced that an RC style controller is about as good as it gets. We did an experiment a few years ago where all the potential drivers tried to use the RC controller vs the traditional dual joystick approach, and everyone preferred the RC controller. It's hard to go back to tank drive after you use a wheel.
Unread 09-12-2015, 15:16
Joining the 900 Meme Team
FRC #0079
Re: Racing Wheels
Any suggested models? I'm game to try it as they aren't terribly expensive but I'd like to cut up one that might work instead of just getting plastic shards all over the place for no reason.
Unread 09-12-2015, 17:22
DanielPlotas DanielPlotas is offline
FRC #1984 (Raider Revolution Robotics)
DanielPlotas will become famous soon enoughDanielPlotas will become famous soon enough
Re: Racing Wheels
148 won a championship in 2008 using an R/C controller like that one.
Sleep? What is that? A rare Pokemon?
Unread 09-12-2015, 18:54
Re: Racing Wheels
Originally Posted by tickspe15 View Post
Or 971
Or 254 and 60 (at least in the past, I know they've used 'em).
Unread 09-12-2015, 19:11
s_forbes's Avatar
Re: Racing Wheels
The lower end Futaba controllers are what we've used in the past. They are all pretty similar; plastic housing with a potentiometer for the throttle and a potentiometer for the wheel. The ones used in the hobby go up in price as features are added, but you just need the housing and the throttle/steering sensors, so cheaper models tend to work ok. (watch out for really really cheap ones though... we had an absurdly inexpensive brand X USB one to play with that we got online, and the resolution for steering and throttle was extremely low. I think it used an IR sensor and a stepped gray-scale pattern on the throttle/steering wheel. It was very unpleasant to use.)
We've wired the pots into analog inputs for the OI in past years. Last year we took an approach that the Bit Buckets came up with, and wired the potentiometers into two of the joystick channels of a gutted logitech gamepad, so we had a USB steering RC controller.
