Go to Post Your opions and statements DO reflect on your team and its' reputation, regardless of what your disclaimer says. - Chris Fultz [more]
Unread 09-12-2015, 13:31
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Intake wheel motors
Originally Posted by Deke View Post
You can run the versa planetary without modifying the CIM output shaft.
We found that that can work but it comes with some caveats.
1. Some CIM motors have the keyseat cut at the back of the output shaft, this makes it near impossible to have any amount of key in the input coupler to transfer toque unless you cut the shaft down some.
2. It adds a lot of length to the whole assembly.
Unread 09-12-2015, 15:08
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
You are correct. I forgot that we did have to sort through our CIM motors to find suitable keyseat flavors.
There were two reasons we didn't want to cut the shaft down.
1. To use the CIM motors for other applications later that required a normal output shaft.
2. With such a long assembly, we had a slightly improved side mounting with the input stage tapped holes kept in the assembly.
