Go to Post Be careful what you wish for, you just might be asked to be on the committee! - Rosiebotboss [more]
Unread 09-12-2015, 09:10
Bluejackets's Avatar
Bluejackets Bluejackets is offline
Bluejacket Robotics
FRC #5464 (Bluejacket Robotics)
Rookie Year: 2015
Bluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to behold
Anderson power pole connections
Rookie question here.
Our FTC team is in last minute need of some red and black power pole connections for our FTC robots and we are not sure which size to order.
We need to add the connections on the drive motors wires that then attach to the speed controllers.
What size should we order and where is a good source.
Thanks for all you do!
Unread 09-12-2015, 09:15
Bluejacket Robotics
Rookie Year: 2015
Re: Anderson power pole connections
I am guessing it is 10 or 12 guage wire but not sure.
Unread 09-12-2015, 09:16
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Andymark sells the appropriate size. If you need significantly more, they have other quantity packages available.
Looks like you're from Minnesota - shipping will take about 2 days.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 09-12-2015, 09:23
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I'd order from here instead, should save some money:
https://www.powell.com/item/Anderson...oparts/3474037
https://www.powell.com/item/Anderson...oparts/3474185
https://www.powell.com/item/Anderson...oparts/3474020
*Verify those are correct parts you want
R.C.
MadTown Robotics Team 1323
Unread 09-12-2015, 10:10
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
We found Amazon to be a good source a few years back when we did our search.
45Amp 20sets for $23
30Amp 100sets for $75
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 09-12-2015, 10:12
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
We have been getting our connectors, wire, and crimpers from here. One stop shop. I have not compared prices but they have it all including nice 6awg battery cable.
http://www.powerwerx.com/anderson-powerpoles/
Unread 09-12-2015, 10:19
serenagh serenagh is offline
Student
FRC #3045 (Gear Gremlins)
serenagh is on a distinguished road
The Neverest motor wires are more like 16 gauge wire, while the tetrix motor wires are something like 18 gauge. My FTC team use s 15 amp and 30 amp powerpoles exclusively- the 45 amp ones are overkill for our application. We get ours from powerwerx- for your situation, I get 50 or so of the 30 amp contacts. http://www.powerwerx.com/anderson-po...pole-sets.html
Also- do you have a crimping tool? Powerwerx sells a nice, racheting one. Saves us time fiddling with crimps. If this is your first time crimping powerpoles, be sure to follow the assembly instructions carefully. They can be tricky. Best of luck!
Edit: are there any local FTC teams you're in touch with? Chances are they have the parts you need, and you can offer to replace there parts when your order arrives- that'll possibly save you the cost of rush shipping them.
Unread 09-12-2015, 11:32
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Powerwerx tends to have my favorite connectors http://www.powerwerx.com/anderson-po...pole-sets.html I have a few spares I could bring up to North Branch with me if you'd like?
See you in North Branch on Sunday!
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 09-12-2015, 12:52
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Yeah, while it doesn't help you now, if you need more at competition come talk to my team (9205, The Iron Maidens)-- I know we'll be bringing up our spare connectors and crimper. If for some reason we don't have it, I'm sure one of the more senior teams (Lazybotts or ICE) would have them. You can also check on the High Tech Kids tournament for a full list of teams, which could help you find one near you.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 09-12-2015, 14:30
Bluejacket Robotics
Rookie Year: 2015
Thanks for all the time and help. I got some ordered and hope the get here by Friday this week. We are keeping our fingers crossed as we compete Sunday in Northbranch. See you guys there and thanks for your time and help with a rookie team.
Go teams!
Unread 09-12-2015, 14:52
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We just put in a big order through Mouser for ours. We haven't received our order yet but I assume they will be fine. If you look up the exact part numbers and order in large quantities they were the cheapest I was able to find. You can also order what ever color you want as well, we are moving to purple and white this year.
45 Amp Tin Contacts $0.105-$0.15 (Tin contacts are rated for fewer mating cycles but we rarely put over 1,500 cycles on any of our contacts)
Red Housing $0.201-$0.33
Black Housing $0.202-$0.38
