Go to Post Of course I'm not an admin, so this opinion is worth about as much as a disco record or AOL Free Trail CD. - PayneTrain [more]
Unread 09-12-2015, 23:47
Kenny Cheung Kenny Cheung is offline
FRC #0008 (Team 8)
Kenny Cheung is an unknown quantity at this point
Automation Direct double solenoid not working?
We recently acquired a couple of these solenoids http://www.automationdirect.com/adc/...)/AVS-3221-24D and have been having issues getting them to work. When we try to fire either side, the green indicator LED on the solenoid turns on and we hear a click but no air is let through. Our PCM is outputting 24V when it should and we have verified the rest of the pneumatic system works (everything works when we use a FESTO solenoid).
Does anyone who has used these solenoids before have an idea what we are doing wrong?
Team 8:
Paly Robotics
2016-present | Team Captain
2015-2016 | Build Captain
2014-2015 | Lab manager
2013-2014 | Build Team Member
Unread 09-12-2015, 23:57
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Automation Direct double solenoid not working?
What pressure are you running them at?
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 10-12-2015, 00:03
FRC #0008 (Team 8)
We are running them at 60 psi.
Team 8:
Paly Robotics
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
I'm not an expert, which is a problem. But yes we bought the same solenoids and have the same problem.
The item you are looking for is the 52 series, not the 32 series. That will solve your problem.
Somewhere around here is an expert that can tell you the difference.
Ed Barker
Unread 10-12-2015, 00:05
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Not an expert, but is the difference 5-port/2 way versus 3-port/2-way?
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 10-12-2015, 00:14
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
A 3 way value can only control one side of a cylinder, they work for single acting spring return cylinders. It opens and exhausts a single line.
A 5 port or 4 way value is used for double acting cylinders.
This FAQ can help.
Unread 10-12-2015, 00:34
Nebster's Avatar
Nebster Nebster is offline
AKA: Ben Kishter
FRC #1306 (BadgerBOTS)
Nebster is an unknown quantity at this point
You might want these .
2015 Wisconsin Regional Chairman's Award - Carson Division
2013 Wisconsin Regional Chairman's Award - Curie Division
Unread 10-12-2015, 09:41
ebarker's Avatar
AKA: Ed Barker
That's what we use, the 52 series
http://www.automationdirect.com/adc/Shopping/Catalog/Pneumatic_Components/Pneumatic_Valves_-a-_Accessories/General_Purpose_Solenoid_Directional_Control_Air_V alves/5-port_(4-way),_2-pos.,_Body_Ported_-z-_Manifold_(AVS-5,AM_Series)
we have both the single and double solenoid versions.,,, we generally use the single solenoid
love 'em
Ed Barker
Unread 10-12-2015, 10:23
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I expect they are pilot operated valve. The solenoid is basically a little valve that operates the spool. If you do not have pressure on the pressure port, they will not work.
Unread 10-12-2015, 14:48
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Did this get resolved?
I work at AutomationDirect and would be happy to help you get up and running.
Unread 10-12-2015, 23:33
FRC #0008 (Team 8)
Thanks for all the help! I think we have a solid theoretical understanding of what we did wrong. Unfortunately we won't have a chance to mess around with it for a while with finals and winter break coming up. If we continue to run into issues later on we will be sure to check back.
Team 8:
Paly Robotics
Unread 11-12-2015, 10:11
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If you have enough of them, as quick workaround, you can use two of the 32 series valves to simulate one 52 series valve. Cross the wires between the two valves so that when one is pressurized, the other is venting, and use one for each half of the cylinder(s).
