Go to Post Chairman's Award is not about building the robot. Every team builds a robot. - Retired Starman [more]
Unread 09-12-2015, 16:47
Knufire Knufire is offline
Ferrules with Weidmuller Connectors on PCM/VRM/roboRio
I know it was mentioned last year that the Weidmuller connectors on this control system were also designed to work with ferrules. Did anyone do this last build season? Did you find it easier than just inserting stranded wire? What size ferrules did you use? Where did you source them from?
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 09-12-2015, 18:02
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
Re: Ferrules with Weidmuller Connectors on PCM/VRM/roboRio
I used extensively for work and would always recommend them when using stranded wire. I also used them for a new controls board for our programmers to be able to develop and train with. It doesn't really change a much for the power distribution board but it makes it much easier for the pneumatics module and voltage regulator module.
For the size part of the question I used a range of sizes for the range for the sizes of wire on the robot. With the different colors it kind of gives it a color code for the different sizes of wire.
McMaster has the full range of sizes with choice of colors. You can probably find them cheaper else where.
http://www.mcmaster.com/#ferrule-terminals/=1063bi3
Unread 09-12-2015, 18:21
chlong chlong is offline
chlong is an unknown quantity at this point
From my experience, using the ferrules was great! They made connecting wires into the Weidmuller connector a lot more easier, it felt like a more secure way of connecting wires to the pcm, vrm, and roborio.
http://www.ctr-electronics.com/catal...ult/?q=ferrule
Those are the ferrules I used.
Unread 09-12-2015, 21:19
mwmac's Avatar
mwmac mwmac is online now
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Very satisfied with how the ferrules worked for us last season and will be using going forward...
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
Unread 10-12-2015, 09:23
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
We had mixed results using wire ferrules last year, and the inconsistency came from one of the two crimpers we used.
One of our crimpers left a smooth surface on the crimped ferrule, and they tended to pull out of the spring-loaded Wago/Weidmuller type connectors pretty easily. The other crimper put a series of ridges across the crimped ferrule, and these were retained much better by the spring-loaded connectors.
The ridged termination crimper is Pressmaster part number DEB-0560.
Unread 10-12-2015, 09:33
mklinker's Avatar
mklinker mklinker is offline
Coach FRC4485
AKA: Mike Klinker
FRC #4485 (Tribe Tech Robotics)
mklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to behold
We also had mixed results. The ferule connectors worked GREAT in the PCM and the VRM but did not work well at all in the PDP. Even with the crimping process creating ridges that the Weidmuller connector could grab we found connections pulling from the PDP often. We ended up leaving the ferule connector on items connected to the PCM and VRM and tinning the ends of stra
nded wires going to the PDP in order to keep them in place.
Mike Klinker Mentor, Tribe Tech Robotics FRC 4485
2016 Walker Warren District Semi-Finalist
2015 Indiana District Championship Semi-Finalist, Purdue District Quarter Finalist, Kokomo District Quarter Finalist, R2OC Finalist
2014 Boilermaker Regional Quarter Finalist
Unread 10-12-2015, 13:30
philso philso is offline
FRC #2587
One of the Austin area teams used ferrules in the 2015 season, 2468, I think. We and some other Houston area teams are considering using them next season. Some of the wire assemblies we get made at work have used them for years.
Make sure you get the proper ferrules such as the one below
http://www.digikey.com/product-detai...0286-ND/448660
I tried using some "wire pin" crimp lugs last season, like the ones linked below. They did not work well because the pin part was a bit big to fit into the small Weidmuller connectors for the low current 12 V connections and the CAN connections. The crimped part also ended up too big to be able to fit more than 3 of them with the 3 mm center-to-center spacing of the Weidmuller connectors.
http://www.digikey.com/product-detai...257-ND/1864557
Unread 10-12-2015, 16:08
Guys,
Not all ferrules are created for this application. My recommendation is that you stay with Weidmuller devices designed for this termination and use only the approved crimping tool. The terminal is designed for a specific cross section that the crimp tool provides.
Unread 15-12-2015, 18:55
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Yup, we used them. Insulated DIN model from automationdirect (ferrules and crimper). This was something we picked up from Dr Jeff and the gang of 2789.
Based on Al's recommendation, I'll investigate the Weidmuller version.
Unread 15-12-2015, 19:00
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Check out http://www.ferrulesdirect.com. They have the best prices and very reasonable hand crimpers. I use them at my company for all wiring purposes.
I would highly recommend using ferrules to prevent stray wire strands from causing shorts. I've see it in industrial field wiring many times and found a few cases on past robots when we didn't enforce using ferrules for all wiring.
Unread 17-12-2015, 16:04
tr6scott's Avatar
tr6scott tr6scott is online now
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
I work in the industrial controls field, or shop had these in-stock, and had great success with them, students love them too.
We use a Weidmuller PZ 6 Roto Wire Crimping Tool to make the crimp.
http://www.chiefdelphi.com/forums/sh...1&postcount=34
The sooner we get behind schedule, the more time we have to catch up.
Unread 17-12-2015, 16:31
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Can you comment on the dies on ferrules direct? Which one do you like best?
http://www.ferrulesdirect.com/Mercha...=DIES4FERRULES
Thanks!
-matto-
