Go to Post They didn’t have to help me. But they did. I have gained so much respect for all the mentors in FIRST from that point on. - Arefin Bari [more]
Unread 12-10-2015, 01:11 AM
ClockworkGold's Avatar
ClockworkGold ClockworkGold is offline
Wears Sparkly Gold Pants
AKA: Andrew F.
FRC #2169 (KING TeC)
ClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to behold
pic: It's so dense every wire has so much going on
Unread 12-10-2015, 01:13 AM
Professional Stat Padder
Re: pic: It's so dense every wire has so much going on
I really like the idea in a lot of ways, however a minor nitpick- if I had to figure out what was wrong with that module, I'd have such difficulty following wires because they're all the same two colors.
Could be a non-issue for your team, I don't know, but that would bother me.
(2015-Present)
Unread 12-10-2015, 08:10 AM
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Team Captain
FRC #3481 (Bronc Botz)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
https://drive.google.com/file/d/0B8z...ew?usp=sharing
We did something very similar this year. We mounted the RoboRio, PDP, PCM, VRM, and Pneumatic gauges and regulators on the top and motor controllers on the bottom so that the module sandwiched the wires. The result was a very clean and elegant control panel that we were able to easily remove in a couple of minutes.
A couple problems with it:
Perhaps it's not the best place to put pneumatics because getting a leak in the middle of the panel is a nightmare.
Also any time you needed to work on the wiring, you have to disassemble the thing which can get annoying after the forty-eighth time.
365 The Decontaminators (FLL) 2011 - 2012
3481 The Bronc Botz (FRC) 2012 - Present
6221 Panther Bots Alpha (FTC) 2012 - 2016
As a FIRST Alum, it's nice to be able to eat dinner again. That is, until I get off the meal plan and have to start feeding myself.
Unread 12-10-2015, 08:50 AM
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
One of the more efficient modular electronics packages I've seen - this might make me rethink using them. When my teams have done them in the past, they've added far too much weight to be worth it.
One small suggestion - it might be worth adding a fan or two to make sure you're getting enough air circulation to keep the motor controllers cool. Assuming you're using the newer, passively cooled models, this isn't as much of an issue as it once was, but it's still recommended to make sure there's enough air flow for the convective cooling to work.
FRC 766, 2015-, Mentor
Unread 12-10-2015, 08:52 AM
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Obviously we do not know the game rules for this year, but 1 rule that probably won't change is that all breakers and the PDP must be easily visible to inspectors. In addition their are diagnostic lights on the PDP that you would not have access too.
I don't see your Circuit breaker either, which needs to be accessible.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 12-10-2015, 09:04 AM
philso philso is offline
FRC #2587
The construction standards would have to be really good. Otherwise, your team will be taking that apart multiple times to find and fix loose connections or crossed wires.
It would also be best to install and wire out extra motor controllers so they can be just connected to the motors. Of course, these extra motor controllers would have to be pre-tested to make sure they are connected correctly so that they will work when needed.
Unread 12-10-2015, 11:43 AM
Mason_Korkowski Mason_Korkowski is offline
FRC #2169
Mason_Korkowski is an unknown quantity at this point
Update to the board
Update on the board. 3 of the corners are pins that pull out easily for inspection. The entire top layer is able to swivel on the remaining pin allowing for the top and bottom layer to be shown. The wires are labled with different colors to easily trace back. And a fan will be added to help cool the motor controllers. The main breaker will be on the robots superstructure to be easily accessed.
Head of Electrical
Side note laser cutting polycarbonate does not work very well with a near infrared laser cutter. The cutter burned the polycarbonate and did not leave clean cuts.
Unread 12-10-2015, 01:14 PM
FRC #2587
Re: Update to the board
Head of Electrical
Do you intend to swing the upper board aside while all the wires to it are connected? If so, you will have to route those wires properly to make this possible. Hinged/moving electrical panels are tricky to do well.
Will the remaining screw/bolt and the corner of the upper panel take the weight of all the components and the attached wires?
It would be better to label your wire pairs and cables (PWM, CAN, sensor) at both ends. Colour coding can be used to identify wires and groups of wires with similar functions.
Unread 12-10-2015, 04:28 PM
FRC #2169
Yes the hinging will happen while the wires are connected. It is hard to see but there is a L shaped hole that allows for the wires to pass through. When the top board rotates on the bolt the L shape allows for extra room for the wires to shift.
As for the color coding goes the 3 wires currently that are the same are the white wires. on both ends of the wires are small colored zip ties. ex(PCM has a blue zip tie on both ends and the VRM has green zip ties)
Unread 12-10-2015, 06:30 PM
llamadon's Avatar
llamadon llamadon is offline
Gold pants swag
AKA: Quinn
llamadon is just really nicellamadon is just really nicellamadon is just really nicellamadon is just really nice
Did you remember to use 12 gauge wire?
Unread 12-10-2015, 07:46 PM
AKA: Andrew F.
Yes. We also remembered who to pick for alliace selections
2014: FRC 2169 Scouting and Spirit & FTC 7897 CAD
2015: FRC 2169 CAD, Strategy, Scouting & FTC Mentor 3385, 3387, 4509, 7899, 7900
Unread 12-10-2015, 08:29 PM
Gdeaver Gdeaver is offline
FRC #1640
Putting all those talons in there can be a thermal problem. I think that it is too tight for a fan to be effective. A FIRST version of an easy bake oven.
Unread 12-10-2015, 10:11 PM
FRC #2587
You will still have to route the wires so they do not impede the motion of the upper board. Often it takes the form of a loop.
You may want to get a label maker such as the one linked below. The wiring then becomes self documenting. They have a deal where you buy a bunch of labels and get the machine "for free". We are now using a similar machine for the equipment we build at work.
http://www.labelcity.com/Rhino-4200-...t-1835374.html
http://www.labelcity.com/Free-Dymo-L...-Purchase.html
Unread 12-11-2015, 12:18 AM
FRC #2169
So we finished putting the whole thing togather and it works very nicely as far as rotating and we do have a label maker.
Unread 12-11-2015, 12:11 PM
Oblarg Oblarg is offline
AKA: Eli Barnett
Just chiming in to let you know how much I laughed at the Rick McCallum joke in the title. A+.
"The breakfast of champions!"
