Thread Tools |
Rating:
Display Modes |
Re: VEXpro 2016
Is the VersaPlanetary Integrated Encoder Thru Coupling the same material as the typical Versaplanetary gearset? Is there a maximum torque/power for the coupling, or is it more likely that other things will break first? This is a 'best practice' question for something like an arm or something like a 2015 tote elevator winch. Phrased via example, would the encoder be safe enough on the last stage in (e.g.) the faster stackers of 2015 or would we want to consider moving it a stage up to reduce its transmitted torque?
Re: VEXpro 2016
-Aren |
Re: VEXpro 2016
Does the VersaDrop only work with two 4" wheels? Or can you use a 4" wheel and a 6"?
Re: VEXpro 2016
The total drop is only ~0.6" (only 0.2" of which is "below zero"), so I'm guessing not as designed. Instead, I'm trying to find out if the gear ratio between the two wheels can be modified significantly.
Re: VEXpro 2016
It's hard to pick a thing to be most excited about.
I'm very thankful for all the effort put into the data gathering on motors. I agree with Richard above that that might be the best gift to FRC in quite some time. Tied with the 775Pro. Tied with the the integrated VP encoder that can do both relative and absolute. (EDIT: See note from Last edited by ahartnet : 10-12-2015 at 18:39. |
Re: VEXpro 2016
This so perfect! Thank you to everyone a part of the Vex team, but one question: Will we ever get a #ballshiftsohard hoodie?
#7
Re: VEXpro 2016
There's a big asterisk on the "absolute encoder" thing. It's still a relative encoder, but it includes it's own counter. It's nice not to have to implement a counter on the rio, but you would still have the problem of the zero changing every time you start up the robot. An actual absolute encoder would give the proper reading no matter how often the sensor had been turned off and moved. (see page 22 of the encoder user guide here: http://content.vexrobotics.com/vexpr...User-Guide.pdf)
I'm wondering - do the rules allow us to power the encoder from a separate 5V battery that we could leave on all the time (even when the main battery is removed)? |
#8
Re: VEXpro 2016
Re: VEXpro 2016
On the subject of the encoder - it looks like it needs a "diametrically polarized" magnet to spin in front of it to work. The user guide I linked has lots of tips for embedding the magnet in existing gearboxes, with the glaring exception of VEX ballshifters (which currently need encoders to have a 1/4" bushing-supported shaft).
I wonder if VEX has a solution already cooked up for ballshifters and these new encoders. If not, I wonder if it would be possible to make a replacement for the plastic encoder gear that has pockets for multiple magnets around the perimeter (or something). |
#10
Re: VEXpro 2016
Edit: Ops thought you were talking about the VP encoder stage. Last edited by Munchskull : 10-12-2015 at 18:29. |
#11
Re: VEXpro 2016
Nope, the ball shifters. Although with a little creativity, maybe the versa planetary stage could be hacked onto the ball shifter...
#12
Re: VEXpro 2016
One thing I'm wondering now is why the 775 didn't get released last year? Its part number is right in the middle of last years numbering, and its drawing says October of 2014.
#13
Re: VEXpro 2016
It'll be fun to swap a couple of these new 775s into our 2015 stacking robot, which currently uses two BaneBots 775s on the lift. Love the specs on this new motor. In theory, you could do a full robot without CIMs, though I wouldn't recommend it. I'm interested in seeing how this plastic tubing holds up too.
#14
Re: VEXpro 2016
Probably took a while to get approval from FIRST. 1323 was testing them on their bot during Madtown Throwdown 2014.
#15
Re: VEXpro 2016
You can think of it like having an MA3 analog encoder and a relative quadrature encoder both kitted in one, which solves several challenges in closed-looping. If you don't move the mechanism and you power cycle the sensor, the bottom 12bits of the analog position remains unchanged. Yes both the absolute and relative positions count the wrap arounds. But this doesn't mean you lose the benefit of absolute position. If you're application does not need wrap-around counting (like a continuous swerve) its pretty easy to add in the number of whole rotations to your 12 bit target position to achieve what you want. In fact this gives you the benefit of absolute position, plus you get to decide which direction you want to servo (always clockwise, always counterclockwise, or choose the path with smallest distance.) |
