Go to Post FIRST is about the relationships you build. ONE individual at a time. - xitaqua [more]
  #46   Spotlight this post!
Unread 10-12-2015, 16:31
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: VEXpro 2016
Is the VersaPlanetary Integrated Encoder Thru Coupling the same material as the typical Versaplanetary gearset? Is there a maximum torque/power for the coupling, or is it more likely that other things will break first? This is a 'best practice' question for something like an arm or something like a 2015 tote elevator winch. Phrased via example, would the encoder be safe enough on the last stage in (e.g.) the faster stackers of 2015 or would we want to consider moving it a stage up to reduce its transmitted torque?
GitHub
  #47   Spotlight this post!
Unread 10-12-2015, 16:34
Aren_Hill's Avatar
Build Nifty Things
Re: VEXpro 2016
This torque spec will be updated on the product page in the coming weeks.
-Aren
A guy who likes robots.
  #48   Spotlight this post!
Unread 10-12-2015, 17:22
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Re: VEXpro 2016
Does the VersaDrop only work with two 4" wheels? Or can you use a 4" wheel and a 6"?
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
  #49   Spotlight this post!
Unread 10-12-2015, 17:25
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Thumbs up Re: VEXpro 2016
Originally Posted by Grant Cox View Post
But wait, there's more..! In addition to these new products, we are also launching some exciting new sections to our website.
Motors.VEX.com - VEX Robotics DC Motor Testing
DC motor selection is an essential part of robot and mechanism design, but the sea of specifications and options available can sometimes be confusing. To help aid budding robot designers in understanding this relationship, VEX has developed an educational guide that explains the four key characteristics of DC motors and how they can be used to select the ideal motor for your application.
Furthermore, to ensure that users have the data needed to make such an educated selection, VEX has tested seven popular motors (including the new 775pro) using industry-standard methods and published motor curves, peak power tests, and locked rotor stall tests for all to see and analyze. Head to http://motors.vex.com/ and pick your favorite motor to get started!
Best gift to the FRC community since the 2005 KoP gearbox.
100% Richard approved.
Richard Wallace
since 2003
  #50   Spotlight this post!
Unread 10-12-2015, 17:30
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Re: VEXpro 2016
The total drop is only ~0.6" (only 0.2" of which is "below zero"), so I'm guessing not as designed. Instead, I'm trying to find out if the gear ratio between the two wheels can be modified significantly.
  #51   Spotlight this post!
Unread 10-12-2015, 17:41
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: VEXpro 2016
775pro - West Coast Products changes the rules of the game. CIM power in a 775 form-factor. You're welcome.
If I'm reading the benchmarks right and doing my math correctly... if you geared down this motor to the same RPM as a CIM, isn't it actually slightly more powerful than said CIM?
  #52   Spotlight this post!
Unread 10-12-2015, 17:47
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant future
Re: VEXpro 2016
It's hard to pick a thing to be most excited about.
I'm very thankful for all the effort put into the data gathering on motors. I agree with Richard above that that might be the best gift to FRC in quite some time.
Tied with the 775Pro.
Tied with the the integrated VP encoder that can do both relative and absolute. (EDIT: See note from nuclearnerd ozrien below)
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
  #53   Spotlight this post!
Unread 10-12-2015, 18:00
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Re: VEXpro 2016
This so perfect! Thank you to everyone a part of the Vex team, but one question: Will we ever get a #ballshiftsohard hoodie?
2014 Dallas Semi-Finalist (Thanks 3847 & 231)
2014 OKC Semi-Finalist (Thanks 2341 & 2461)
  #54   Spotlight this post!
Unread 10-12-2015, 18:01
AKA: Brendan Simons
FRC #5406 (Celt-X)
Re: VEXpro 2016
There's a big asterisk on the "absolute encoder" thing. It's still a relative encoder, but it includes it's own counter. It's nice not to have to implement a counter on the rio, but you would still have the problem of the zero changing every time you start up the robot. An actual absolute encoder would give the proper reading no matter how often the sensor had been turned off and moved. (see page 22 of the encoder user guide here: http://content.vexrobotics.com/vexpr...User-Guide.pdf)
I'm wondering - do the rules allow us to power the encoder from a separate 5V battery that we could leave on all the time (even when the main battery is removed)?
  #55   Spotlight this post!
Unread 10-12-2015, 18:02
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: VEXpro 2016
It truly is a Merry Vexmas!
  #56   Spotlight this post!
Unread 10-12-2015, 18:03
ahartnet's Avatar
Re: VEXpro 2016
Thanks for the catch. Definitely a big asterisk that I'm glad you pointed out. Got wrapped up in too much excitement!
  #57   Spotlight this post!
Unread 10-12-2015, 18:14
AKA: Brendan Simons
FRC #5406 (Celt-X)
Re: VEXpro 2016
On the subject of the encoder - it looks like it needs a "diametrically polarized" magnet to spin in front of it to work. The user guide I linked has lots of tips for embedding the magnet in existing gearboxes, with the glaring exception of VEX ballshifters (which currently need encoders to have a 1/4" bushing-supported shaft).
I wonder if VEX has a solution already cooked up for ballshifters and these new encoders. If not, I wonder if it would be possible to make a replacement for the plastic encoder gear that has pockets for multiple magnets around the perimeter (or something).
  #58   Spotlight this post!
Unread 10-12-2015, 18:26
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: VEXpro 2016
The sensor provides both an absolute and a relative position. The "absolute position" is an absolute 12bit encoded value that wraps every rotation. This works similarly to the MA3 absolute analog encoder which gives you an absolute voltage (0 to 3.3V) for one full rotation.
You can think of it like having an MA3 analog encoder and a relative quadrature encoder both kitted in one, which solves several challenges in closed-looping.
If you don't move the mechanism and you power cycle the sensor, the bottom 12bits of the analog position remains unchanged.
Yes both the absolute and relative positions count the wrap arounds. But this doesn't mean you lose the benefit of absolute position. If you're application does not need wrap-around counting (like a continuous swerve) its pretty easy to add in the number of whole rotations to your 12 bit target position to achieve what you want. In fact this gives you the benefit of absolute position, plus you get to decide which direction you want to servo (always clockwise, always counterclockwise, or choose the path with smallest distance.)
  #59   Spotlight this post!
Unread 10-12-2015, 18:27
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Re: VEXpro 2016
It has one.
Edit: Ops thought you were talking about the VP encoder stage.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
  #60   Spotlight this post!
Unread 10-12-2015, 18:42
AKA: Brendan Simons
FRC #5406 (Celt-X)
Re: VEXpro 2016
Nope, the ball shifters. Although with a little creativity, maybe the versa planetary stage could be hacked onto the ball shifter...
