Go to Post Your opions and statements DO reflect on your team and its' reputation, regardless of what your disclaimer says. - Chris Fultz [more]
Unread 10-12-2015, 16:27
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
Team 1658 prototype flying inverse differential(gyro-encabulator) bi-swerve
A unique, one of a kind, never before seen drive system. We have two flying inverse differentials(gyro-encabulators) that each power two swerve wheels for a complete robot. Stay posted for video!
ID:	19537  Click image for larger version
ID:	19538  Click image for larger version
ID:	19539  Click image for larger version
ID:	19541  Click image for larger version
Unread 10-12-2015, 16:38
Ari423's Avatar
Happy Birthday! Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: Team 1658 prototype flying inverse differential(gyro-encabulator) bi-swerve
Besides the coolness factor (which, btw, is off the charts) what is the point of designing a drivetrain like this? It looks more complicated and more motors than a normal swerve drive (which is an accomplishment in and of itself).
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 10-12-2015, 16:54
FRC #1658
Actually it uses the same allotment of motors as a regular swerve so we don't lose anything there. as far as the point of doing it, it's multi faceted. with normal drive systems and the systems that are used for FRC, when you want a motor to go slowely or just a little bit, it often lacks the power to move at those lower values, so you have to give it a higher value than desired to get it to even move. with this design. you can move at 10% speed but have as much power as possible and make micro movements for very precise aiming without overshoot. if we run the reference motors at 100% all out, and the other one at 90% in the reverse direction. the total output will be 10%... at 90% of the motors power. At worst it will perform like a normal swerve when they spin the same direction, but when they spin opposite directions you get that major benefit at having lots of power at low speed so it offers a lot more versatility.
Unread 10-12-2015, 17:21
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
That's really cool! I love the engineering and fabrication that went into this. The only thing I would suggest is to consider a way to lock your differentials if necessary (either with a limited-slip design, or a pneumatic clutch). Right now, if your robot loses traction on any corner (going over a field obstacle, or being lifted in defense), the unloaded wheel will spin freely, sapping all power from that side of the bot. (unless I'm misunderstanding the design)
Unread 10-12-2015, 17:23
AKA: Brendan Simons
FRC #5406 (Celt-X)
Oh, I am misunderstanding. I thought the differential split the power between wheels, but it splits the power between two motors to make an infinitely variable transmission. Neat!
Unread 10-12-2015, 17:24
FRC #1658
indeed you are. this is an inverse differential not a normal differential. the wheels are locked together in speed so it doesn't matter if any of them lose traction. you can see the chain routing, it's impossible for any of the paired wheels to move at a different speed than the wheel it's paired to.
Here is a bonus pic, almost like a kit. https://i.imgur.com/QohIBXS.jpg
Unread 10-12-2015, 17:26
FRC #1658
yup exactly. all without any additional motors or actuators than what would be required for a normal swerve. More complex? yes. Although it's less complex than a shifting one would be. Worth it? We shall see.
Unread 10-12-2015, 18:01
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
I know I'm focusing on the "wrong part" but those Jags that appear to be nearly floating amuse me.
Looking forward to the video.
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 10-12-2015, 18:06
FRC #1658
ye we were short 2 SRXs. We have 1 coming as part of first choice whenever that comes in and we'll order 1 more. but won't let that stop us from advancing the project xD I have come to have a major dislike of jags. the SRXs are a beut though.
Unread 10-12-2015, 20:23
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Anyone who saw 1658's robot from last year knows they are an up and coming powerhouse of the St. Louis area. This off-season prototype is crazy awesome, can't wait to see some video of it running!
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 10-12-2015, 21:38
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Team Role: CAD
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
I had a similar idea over the summer, but I never had time to design it. Looks awesome!
Are there any apparent problems? Does the differential work as planned?
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 10-12-2015, 21:53
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
This is amazing. That is about as close to the definition of inspiring as I know of. Fantastic. Wow.
http://www.angelbotics.com
Remember why you're doing this.
Unread 10-12-2015, 22:32
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
I'm sure it's not optimized for weight yet, but what does it weigh?
Unread 11-12-2015, 00:19
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
This is the coolest swerve drive (or drive, really) I have ever seen!
As far as this versus a shifting swerve goes, an IVT only gets a maximum torque equal to the maximum torque at the lowest gear ratio, so lowering the speed does not increase your torque unless the motors are drawing more current (not sure on that last part). I really want to see efficiency/ acceleration specs on this beast.
You also won't be able to do turn + drive maneuvers without scrubbing, it looks like, but you hardly need those anyway.
Unread 11-12-2015, 00:34
AKA: Brendan Simons
FRC #5406 (Celt-X)
What algorithm are you using to choose the motor speeds? Lets say you want to speed up the right side. You could speed up the top motor, slow down (or reverse) the bottom motor, or some combination of the two. How do you avoid running either motor at an inefficient part of its range (such as stalling one while the other runs flat out)? Just curious.
