Go to Post Wait hold the phone. Do you mean its physically possible to not spend time on robotics during the season?!!! Too much.......for brain......to compute!...goes against.....beliefs........aaaaarrrrrrghhhhhh!!! [syntax error] - BuddyB309 [more]
Unread 24-03-2003, 17:00
Coach C's Avatar
Coach C Coach C is offline
#0341 (Miss Daisy)
Coach C is an unknown quantity at this point
Occasionally - depending on how your solenoids are wired/programmed - we found that a dropped packet could set off our pneumatics. Low battery voltage seemed to exaggerate this. Just play with the solenoid and program - experiment with ports that are normally opened and normally closed until you find a setting that works.
If you have a castor shooting down accidentally, your robot might be sent into more of a spin, hence the 90 degree turns.
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
