Go to Post Yeah refs are trained to not have a sense of humor about things like that. - Koko Ed [more]
Unread 11-12-2015, 12:57
first_newbie first_newbie is offline
FRC #1718
first_newbie is a jewel in the roughfirst_newbie is a jewel in the roughfirst_newbie is a jewel in the rough
FRC drive train
What is shake in terms of drive train in frc? Sorry for all the questions.....
Unread 11-12-2015, 13:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: FRC drive train
Questions are good! no need to apologize.
It might help if you can provide some more context for your question. I dont know what "shake" is...could be a few different things...with several different causes.
Unread 11-12-2015, 13:16
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: FRC drive train
The only example of a shake drive I'm aware of was the "Harlem Shake" routine at this post.
Unread 11-12-2015, 14:20
FRC #1718
Re: FRC drive train
http://www.chiefdelphi.com/forums/sh...38049&langid=2
References of shake on the aforementioned thread
Unread 11-12-2015, 14:31
EricH EricH is online now
Re: FRC drive train
In that particular context, I believe it's referring to the ability of a robot to hold a straight line without swerving all over the place.
Typical characteristics of an FRC drivetrain (no descriptions): speed, traction, number of speeds (and spread of the gear ratios), wheelbase & trackwidth, overall type (of which there are several: tank, swerve/crab, mecanum, omni, H/I drive, and the various subtypes of butterfly drive), and for tank drives the drop of the center wheel.
Non-typical characteristics: shake.
Unread 11-12-2015, 14:32
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: FRC drive train
This referenced the "rocking" motion of a drop center drive chassis in the pitch axis. In drop center, there are three (or more) pair of wheels, and the pair(s) in the center are positioned a bit lower (typically 1/8") below the line connecting the front and rear axles. This drop allows the robot to have the advantages of a short wheelbase for purposes of being able to turn, and those of a long wheelbase for purposes of not falling over forward or backwards. The cost is a bit of rocking motion as the robot shifts from one axle to another. For some games, this is of little or no consequence, but for others where the robot may be very tall, have a long arm, or be aiming at a goal with a tight vertical tolerance, the amplification of that 1/8" can be a problem. For more detail on why drop-center, see this classic white paper.
