Go to Post Batteries don't help you if they're lying on the field. - Kevin Sevcik [more]
Unread 11-12-2015, 18:21
FrankenmuthK's Avatar
FrankenmuthK FrankenmuthK is offline
FRC #5215
FrankenmuthK is an unknown quantity at this point
POV
Semi-new programmer here. What is the POV on a joystick and controller mainly used for?
Unread 11-12-2015, 18:49
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: POV
We have used it for things with multiple discrete steps, to increment/decrement among them. Examples include lifting one tote level for 2015 Recycle Rush and panning across the camera view for alternate goals, e.g. in 2012 Rebound Rumble. We used this (or something similar; perhaps it was keyboard driven) to step through the various stages of climbing for 2013 Ultimate Ascent; if all went well, you just kept clicking "up".
At a somewhat less intuitively obvious level, the POV could be used to choose among up to four drive formats (e.g. arcade, tank, arcade-with-slide, or translate-with-twist), or to "shift up or down" among various maximum speeds.
Unread 11-12-2015, 22:02
Re: POV
It is essentially a group of closely spaced buttons, but only one of them can be pressed at a time. They have many uses, especially for a mechanism with a variety of settings.
Greg McKaskle
