Re: SprocketR - Custom Sprocket Web Application
Cool! I have a couple of questions:
1. The chain sizes are in inches and the c2c distance is in mm . What's the reasoning behind that? Can you make an option in inches?2. When would you want slack in your chain? I've heard that some people add a little bit of c2c distance to get tighter chain. |
The main SprocketR developer is deep in finals this week, so I thought I'd go ahead and respond. I'm one of the mentors working with the Chap Research team on SprocketR.
>> 1. The chain sizes are in inches and the c2c distance is in mm . >> What's the reasoning behind that? Can you make an option in inches? We don't have a lot of options in SprocketR yet. Things are rather hardwired to mm right now. We intend, though, to make "units" an option in the future. For chain, we just used the "industry" designation of #25 and #35, which aren't really in inches. >> 2. When would you want slack in your chain? I've heard that some people add a >> little bit of c2c distance to get tighter chain. There is an "best" amount of slack for a chain that promotes the best wear on the teeth on the sprocket...which is particularly important for SprocketR given that the resultant teeth are made of plastic. Further, a bit of slack allows the chain to position itself on the sprocket during uptake, where an absolutely tight chain may bind, again, particularly on a plastic sprocket which isn't as rigid as a metal sprocket and may not be perfectly flat under a load. SprocketR bases calculations on the "perfect" or "ideal" chain length, which is not attainable since a real chain's length is a multiple of the length of a single chain link. So SprocketR rounds-up to the nearest chain link length taking into account the desired slack. Having said all of that, you can absolutely specify zero slack if you want, though you're likely to get just a bit of slack anyway since the chain length will likely be longer than the "ideal length" given that it must round up to the nearest whole link length. We have found that 1% is an appropriate target chain length, which is the program's default. |
Looks great! I can foresee frequent visiting in my future.
I have one suggestion: Have a minimum/maximum gear ratio, or incorporate some sort of tolerance. think Also, I'm not sure if this is the intent of the project, but you might consider an option for outputting the 2d profile for lasercutting or waterjetting. |
Looks really cool - it saves me from having to go to SDP-SI to track down step files of sprocket geometry, which can be a pain sometimes. I also like the preview ability to see roughly the size of the sprocket.
Slack is definitely a big issue, and we feel it potentially gets more "delicate" which you have plastic sprockets, which is one of the reasons that SprocketR exists - to find the right target for you. We believe like you that a tight chain is a good chain, and the industry seems to have some guidelines too.
Our percentage measurement isn't done, however, like these references suggest. We provide a slack relative to the overall length of chain. The 1% is our attempt at a useful slack that doesn't provide a loose chain that can jump. However, we don't have a bunch of empirical data...yet...that's one of the reasons we have the SprocketR out now! We'd like to use a bit of crowd-sourced testing. Quote:
Thanks for the help! We want to make the SprocketR as useful as we can. |
