Go to Post And when the President of the United States is playing with LEGOs and getting down on the floor to look inside of robots, then I would have to say "Mission Accomplished". - OZ_341 [more]
Unread 10-12-2015, 12:51
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Joining perpendicular tubing
Stupid question, how this construction method works eludes me. How do you attach a bolt into a piece of hollow tubing, with no gussets/welds? What is there for the bolt to hold on to? Is there some block within the tube that includes a threaded hole for bolts to pass through?
Pic of 610's 2013 chassis for reference. I'm looking at the transverse tubes and where they join with each side of the drivetrain.
2012 - 2015 • Team 2601
Unread 10-12-2015, 12:53
Re: Joining perpendicular tubing
The rods are threaded (tapped).
Sorry I misunderstood.
Certainly blocks filling the ends are easy, and could be spot welded internally.
Unread 10-12-2015, 12:54
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Originally Posted by Mark McLeod View Post
The rods are threaded internally.
I think he's talking about the ladder rails going across the frame, not the standoffs on the sides.
Unread 10-12-2015, 12:55
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
If I recall correctly, 610 uses a kind of unusual method of doing this. They use three pressed roll pins in the plate to capture the tube geometrically in the corners, and in the fourth corner, run a length of allthread to pull the whole thing together while making it removable.
Unread 10-12-2015, 12:58
NWChen's Avatar
Alum
Yup, thanks though Mark.
Oh, I see that in their design tutorials. Is there another way of doing this kind of attachment?
Unread 10-12-2015, 13:04
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Here is a close up of the joint.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 12-12-2015, 09:26
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Yes, McMaster-Carr sells tube insert nuts:
http://www.mcmaster.com/#steel-tube-...-nuts/=107gcqp
While they technically work, we had enough problems with them to move to the 3 roll pin + threaded rod solution instead.
I think they're okay for prototyping, but on a competition FRC robot they come loose too often.
Not a stupid question at all. It took us a long time to figure out how to do this, and we still don't stop trying to improve on things like this.
Others have already posted info about how we did this above, and you mention you read our Design Tutorial which has the best description of this process available, but to answer your questions directly here:
We drill 4 holes at the inside corners of the square tube. 3 of the holes have roll pins pressed in, and they help position the square tubing. The 4th hole is for a threaded rod that runs the entire length of the square tube. One of the bottom holes is usually used for the threaded rod so that gravity helps you position and line it up. Access pockets along the length of the square tube are helpful in case you need to manipulate the threaded rod. Often we put a Nylock nut on one end of the threaded rod, and a Keps nut on the other so that tightening and loosening doesn't spin the rod - you only turn the Keps nut. The 3 roll pins take the shear load, and the threaded rod holds the plate against the tube.
Nothing but the plates. The threaded rod runs the entire length of the tube, so the only thing keeping it in place are the nuts on the ends of the rod.
No. Nothing is needed inside the tubes.
In life, what you give, you keep. What you fail to give, you lose forever...
