Go to Post But that is not all-FIRST is about teaching mentors what kids are like all over again. It's about closing the generation gap, creating bonds, life time friends, and skills that will last everyone involved a lifetime. - Team0 [more]
  #46   Spotlight this post!
Unread 12-12-2015, 19:15
Michael Hill's Avatar
Re: FRC pocketing
Originally Posted by Ryan Dognaux View Post
http://www.harborfreight.com/34-in-2...-pc-68113.html
95% of FRC teams should have a set of these and use them often. We had a lot of 1/8th inch 2" x 1" aluminum last year that got cheesed significantly by some of our students that needed something to do.
We always try to come in under weight and adding some lightening holes only helps in a lot of areas of the robot. Cheese early, cheese often.
I just bought that exact set the other day for our team. It was the most reasonable one with a 1 1/8" saw. We were hoping to use it mostly on wood, but since the teeth are HSS, I thought it had potential aluminum use. Does it work well? How many more files will we need to buy to get rid of the burrs? :-P
  #47   Spotlight this post!
Unread 12-12-2015, 20:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: FRC pocketing
Originally Posted by Alan Anderson View Post
I see a bunch of trusses at various scales, but no pocketing jumps out at me. Am I missing something?
They're functionally the same, though how you get there is different. There are definitely pockets on the bridge - large oval ones about a foot and a half wide and three feet long. Some (especially those on the old middle segment with the train) are really intended as access holes for riveting, but the ones on the outer tubes are just there to reduce weight. The easiest examples to see flank the vertical beam that drops from that large multi-directional joint to near the center of the white boxcar.
While we haven't done any lightening holes the past three years, we've found that cutting large holes in 1/8" or thinner aluminum (e.g. for pneumatic cylinder and bearing mounts) is easier, faster, and cleaner with a spade bit than with a hole saw. If access allows, we score the outer circle on one side, then complete the cut on the other.
Edit based on a later post:
Originally Posted by Everett33 View Post
I am not sure on the lifespan yet, but I have had very good success using this tool for drilling through 1/8" and 1/16" aluminum with a cordless drill. It produces a very nice hole in a very short time without the need for any cutting fluid.
http://www.menards.com/main/electric...80219544263520
Very cool; halfway between the spade bit and the hole saw - with carbide teeth. I noticed on the Menard site that it's intended for making knockouts in steel boxes, and useful for stainless. As such, it should have an excellent lifespan on aluminum.
  #48   Spotlight this post!
Unread 12-12-2015, 20:54
Everett33's Avatar
Everett33 Everett33 is offline
AKA: Everett Owen
FRC #2145 (HAZMAT)
Everett33 is on a distinguished road
Re: FRC pocketing
ID:	19550  Click image for larger version
I walk the pits of FIM and take cool robot photos.
•Lead Driver 2009-2013 •Mechanical Mentor 2014-2015
•Record of 6-2
  #49   Spotlight this post!
Unread 12-12-2015, 21:06
AdamHeard's Avatar
Lead Mentor
Re: FRC pocketing
For those considering .125 wall versus .063, by the time you pocket .125 to be the same weight as .063 unpocketed it will actually be weaker.
Thin wall tubing is one of the best things for saving weight.
  #50   Spotlight this post!
Unread 12-12-2015, 21:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: FRC pocketing
I wish VEX Pro sold VersaFrame without the holes in it.
  #51   Spotlight this post!
Unread 12-12-2015, 22:14
AdamHeard's Avatar
Lead Mentor
Re: FRC pocketing
Coast Aluminum will sell you that... for a much better price.
  #52   Spotlight this post!
Unread 12-12-2015, 22:52
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: FRC pocketing
Absolutely! Without the holes, there are a great number of suppliers available, many at a much lower cost. The value added of VersaFrame is in the pre-drilled holes, which should improve consistency between our practice and competition robots.
  #53   Spotlight this post!
Unread 12-12-2015, 23:03
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Thanks for this we are ordering one.
  #54   Spotlight this post!
Unread 12-12-2015, 23:36
Re: FRC pocketing
I assume you are talking about the outside dimensions, and not the 0.100" thickness.
  #55   Spotlight this post!
Unread 13-12-2015, 00:11
Re: FRC pocketing
With 0.1 or 0.040 wall thickness?
  #56   Spotlight this post!
Unread 13-12-2015, 00:23
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: FRC pocketing
.060" & .125"
R.C.
MadTown Robotics Team 1323
  #57   Spotlight this post!
Unread 13-12-2015, 13:45
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Re: FRC pocketing
Originally Posted by Cory View Post
You should investigate using 1/16 wall tube if you frequently have this problem. It's going to be stronger than a heavily pocketed out 1/8" wall tube.
Totally agree - we had already purchased a lot of 1/8" thickness material and didn't have 1/16th yet. We later swapped our elevator railing to 1/16" thickness with no holes and loved it.
We pretty much used all 1/8th 2" x 1" on our drive train though and used the hole saws to take some material out. It's just too convenient for us to go any thinner on the drive since we can press bearings in as needed and not really need to worry about adding extra material.
Originally Posted by Sanddrag
That Harbor Freight set is pretty inexpensive. Does it work well? For anyone looking for a high-quality hole saw set, I've been very happy with this set.
The answer, as with everything from Harbor Freight, is it depends on the application. We cheesed some thin plate material this year with them and we also cut holes in 1/8" thick aluminum with them. With the thicker material I'd highly recommend vigorous use of cutting fluid. After about 100 holes over two robots this year we killed one of them, which isn't really surprising. For the price they do a decent job.
That's when you break out your cheap angle grinder that you also purchased at Harbor Freight http://www.harborfreight.com/4-12-in...der-69645.html - obviously doesn't work too well for the interior burrs but we weren't too concerned with those. Can hit those with your Dremel tool as needed.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
  #58   Spotlight this post!
Unread 13-12-2015, 19:03
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: FRC pocketing
I thoroughly recommend purchasing one or two deburring knives. One of my favorite tools in the lab.
Not the one we have, but virtually the same
http://www.homedepot.com/p/HDX-Debur...X090/204218603
  #59   Spotlight this post!
Unread 14-12-2015, 12:40
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
Re: FRC pocketing
Originally Posted by s_forbes View Post
Hi all, just got my first pocketed gearbox plate off the mill. plz r8.
This is the best post. I hope to see you at Flagstaff in March.
KF6UZX
  #60   Spotlight this post!
Unread 14-12-2015, 13:47
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: FRC pocketing
I'm sure I'll find you first, assuming you guys make more awesome gearboxes! I haven't had a chance to see one in person. They look much better than my collection of sponges.
