Go to Post Can't engineers be jesters? - danielkitchener [more]
Unread 13-12-2015, 12:06
first_newbie first_newbie is offline
FRC #1718
first_newbie is a jewel in the roughfirst_newbie is a jewel in the roughfirst_newbie is a jewel in the rough
FRC T-bone-ing and Hexagonal drive
Is T-bone-ing just when two robot clash head to head? Also what are the benefits of a hexagonal drive train?
Unread 13-12-2015, 12:17
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: FRC T-bone-ing and Hexagonal drive
T boning is when the front of one robot hits the side of another robot.
Hexagon drive train lets you build a robot without as severe of "corners", might be easier to get around other robots or obstructions.
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
T-Boning is when one robot "crashes" into the side of another robot. It's one of the most popular and easy ways to play defense because when you ram into the side of another robot and they try to drive forward, they're going to go in circles because the side of their robot that you are driving against can't move. This is furthermore effective because it technically does not count as pinning a robot. The advantage of a hexagonal drive train is that you cannot T-bone them because they don't really have a flat side to push against.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 13-12-2015, 12:19
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
T-boning is when one team is pushing against the side of another robot, creating a T shape if both robots are long or both robots are wide.
Sometimes hexagonal bumpers help so that a team can only push their bumpers against a component angle of your side bumpers, allowing you to get out of a T-bone. Depending on how the team T-boning you orients themselves, hexagonal bumpers may not work.
Watch defense played on 971 in this match. Occasionally when a robot makes contact to the side of their robot, they can roll out quickly. Occasionally they can't. https://youtu.be/G07Ci0VcUjs?t=40s
It certainly can't hurt to make your bumpers hexagonal, but you should ask yourself two questions before you decide to do so.
Is my team a major target of defense?
Is this the most effective use of my resources in handling defenders?
MORT Team 11: 2008 - 2015
MKI Team 1923: 2015 - Present
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
T-bone-ing is when one robot's front pushes another robot's side. If the robot being pushed has traction wheels, this increases the friction on the pushed robot's wheels to the point where it cannot move. It is debated whether or not this should count as a pin, but as of 2014 it did not.
By hexagonal drive do you mean a normal robot with a hexagonal perimeter or a drive system where each side has an omni wheel?
EDIT: sniped x3
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Last edited by Ari423 : 13-12-2015 at 12:22. Reason: apparently I'm a really slow typer
Unread 13-12-2015, 12:20
FRC #1718
Are there any technical advantages of a hexagonal drive?
Unread 13-12-2015, 12:26
Ari423's Avatar
FRC #5987 (Galaxia)
A hexagonal robot (if done correctly) is less susceptible to T-bone-ing in most cases. Other than that, not really. I usually find that the benefits don't outweigh the consequences. They are more complicated to design and build than a traditional rectangular bot, so you may want to choose to stick with a more basic drivetrain and work on making a kick @$$ manipulator. That's up to your team based on your team's resources and how your team wants to play the game.
P.S. If you are going to make a odd-sided drive, make a nonagon. 100% of nonagonal robots have won Einstein.
EDIT - I didn't know CD automatically sensors "curse words"
2013: Programmer
Unread 13-12-2015, 12:36
jijiglobe's Avatar
FRC #0694
One solution to the T-boning problem that is much simpler to implement is to make your bumpers out of different types of fabric. Many teams use a high friction cloth (such as emery cloth) for their front and back bumpers so that they can T-bone other teams, while using low friction cloth (such as sail cloth) for their side bumpers. so that other teams have difficulty T-boning them.
EDIT: Emery cloth is way too abrasive to be used on bumpers
RoboRio
Rob/oRio
oRio
Unread 13-12-2015, 12:45
FRC #1718
What are the consequences of a hexagonal drive then? Can you send me a picture of the nonogonal robot?
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
That sounds like such a dirty way to play and I love it. Kinda like pine-tarring in baseball, but for robots.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 13-12-2015, 12:46
FRC #1718
Wait is the nonogonal robot 148's tumbleweed?
Unread 13-12-2015, 12:48
FRC #1718
Are hexagonal drive train any better at turning?
Unread 13-12-2015, 13:01
jkelleyrtp's Avatar
AKA: Jon Kelley
A common thing on CD recently is just building outskirts out of sheet or tube in a pointed fashion to mimic hexagonal bases on top of a basic drive. All it really boils down to is bumper placement. See 148's x009 chassis.
Mechanical, CAD
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Yes it was.
Unread 13-12-2015, 14:03
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Yep, the bumper material is the most important material in the first place. A hexagon with cordura will have a lot more trouble then a square frame with nylon or sail cloth. Changing bumper material the first option a team should consider before changing their frame.
Right now on 3476, we are practicing sowing with these new materials, that's more important to us then working with a new hex frame.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
