Go to Post Engineering still can't beat Physics! - Manoel [more]
Unread 13-12-2015, 15:49
first_newbie first_newbie is offline
FRC #1718
first_newbie is a jewel in the roughfirst_newbie is a jewel in the roughfirst_newbie is a jewel in the rough
FRC COG
Can someone please help me understand COG in FRC
Unread 13-12-2015, 15:51
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: FRC COG
COG stands for Center Of Gravity. It is basically the point where the mass of your robot is distributed on average. More weight at the top of your robot means a higher COG, which means your robot has to tip to a smaller angle before it will completely fall over.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 13-12-2015, 16:28
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: FRC COG
old paper I wrote. Might get you some of the basics.
http://www.chiefdelphi.com/media/papers/1974
Unread 13-12-2015, 19:44
Darren Collins Darren Collins is offline
Coach
AKA: Darren Collins
FRC #2046 (Bear Metal)
Darren Collins is a name known to allDarren Collins is a name known to allDarren Collins is a name known to allDarren Collins is a name known to allDarren Collins is a name known to allDarren Collins is a name known to all
Re: FRC COG
In some cases, people use COG to mean Center of Geometry instead of Center of Gravity. You will need to consider the context to determine what the writer is referring to. Here is an example where COG is referring to Center of Geometry.
http://www.chiefdelphi.com/forums/sh...ht=COG+Physics
http://tahomarobotics.org
Unread 13-12-2015, 22:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: FRC COG
In addition to the height and the possibility of tipping, the lateral location of the CoG (gravity) is also important when figuring out what a robot will be like when turning or being pushed into a turn. If the CoG is essentially over one axle of a drop-center drive, the other wheels will carry little weight and the robot will turn very easily, but also be easy for other robots to cause you to spin by pushing you away from the CoG axle. If the CoG is squarely between two axles, you may have a bit more trouble turning (though if the length of that segment is significantly less than the track width, you shouldn't have a problem) but you will also be more resistant to being turned externally.
