Go to Post Free food attracts us like flies. It's the one sure way to get us to meetings. - Mark McLeod [more]
Unread 13-12-2015, 19:58
bmammen's Avatar
bmammen bmammen is offline
AKA: Brent Mammen
FRC #5801 (Inspire)
bmammen is an unknown quantity at this point
Re: Swerve and Steer Module
Originally Posted by page2067 View Post
We were psyched to hear that a team that did as well as you guys used our code as a basis.
Congratulations on a great year!
Our programming team will be posting our past year swerve update later this fall. Our code and some powerpoint that describes the basis for it are on our resource tab of our website.
We appreciate hearing from teams that find it useful.
Any idea when you might post last seasons code? Curious what changes you guys made, your bot was very smooth on the field!
Unread 13-12-2015, 20:18
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
Originally Posted by Peyton Yeung View Post
Here are some pictures of the setup.
The encoder has a 1/4" output so I took a 3/8" hex shaft, drilled a 1/4" hole in one end, slotted the hole with a band saw, and slid a shaft collar over the slot and voila. The encoder now has a 3/8" hex shaft which I coupled with a 3/8" hex gear with the same number of teeth so the feedback is 1:1. The whole plate has just 5 holes in it.
So the 3/8" hex shaft acts like a collet clamping onto the encoder shaft? That's a pretty neat set up!
CAMS Robotics, FIRST Team 687 The Nerd Herd 2010-Present
College Mentor 2013-Present // Design Chairman 2012-2013
Berkeley High Robotics, FIRST Team 5499 2014-Present
College Mentor 2014-Present
